6.4 transmission - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 06-14-2014, 12:42 PM Thread Starter
Stumppy's Avatar
6.4 transmission
So my transmission went out in in my truck and I found another locally brand new for 1500 but it has a 6.4 tc with it. If I just swap flywheels that should be all I need right? Everything else should be the same? I've read on a few past threads that I might need a separate controller for it but have never heard of that before. Any help would be great.
2004 CC SB 6.0
4 Inch Turbo back Exhaust
S&B Intake
Sct with Vivians looney wild tune.
Egr Delete
Arp Head studs and oem gaskets.
Stumppy is offline
post #2 of 13 Old 06-14-2014, 07:20 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 105 Post(s)
Feedback Score: 3 reviews
Last I knew swapping the flywheel or torque converter was all that was required.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 13 Old 06-15-2014, 07:01 AM
scparrish's Avatar
Quoted: 84 Post(s)
A separate controller won't be necessary
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
post #4 of 13 Old 06-15-2014, 07:34 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
The flex plate(8 stud holes instead of 6) is all I was told also. The reason a standalone controller was mentioned was because the 6.4 uses a separate TCM. The reason it does this is because the injector driver is internal to the PCM, unlike a 6.0 which has a combination PCM/TCM and a separate injector driver (FICM). That is where the confusion originated from, the 5R110W for all years is controlled the same way.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 13 Old 06-15-2014, 07:35 PM Thread Starter
Stumppy's Avatar
That's good to know. I'm throwing it on Thursday since I have the day of and hopefully get it back on the road.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #6 of 13 Old 06-16-2014, 10:41 AM
The balance on the flywheel could be different from a 6.4 to the 6.0 since the are a different engine. Yes the bolt pattern is the same on the crank but the front pulley is way different. I would put the correct torque converter in it for the 6.0 not swap flywheels. You don't want an engine balance problem to wipe out the bottom end of your engine.
Diesel Equipment service manager lead technician
jpott62 is offline
post #7 of 13 Old 06-16-2014, 12:02 PM
peixinho's Avatar
Quoted: 193 Post(s)
From what I have been told... you just need to put an aftermarket converter on the 6.4 transmission that has both the 6.0 and 6.4 mounting holes. Then it should bolt right up. I know my tranny is out of a 6.4 and it was built by andy warren. They both look identical and everything bolted up just fine.
I am not sure if any of the sensors are different but you could easily swap that over from your core 6.0 tranny.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #8 of 13 Old 06-16-2014, 02:05 PM Thread Starter
Stumppy's Avatar
The transmission came with a tc. It will be cheaper to just buy the flex player and swap it out then to buy another tc. I'm not to worried about balance problems. From what I've read people have done it with no issues at all.
2004 CC SB 6.0
S&B Intake
Egr Delete
Stumppy is offline
post #9 of 13 Old 06-16-2014, 02:28 PM
Might not but I wouldn't chance it. Engines aren't cheap.
Amfw119 likes this.
jpott62 is offline
post #10 of 13 Old 06-17-2014, 11:57 PM
Anyone know if the harness plug is the same? Is it plug and play electrically?
2005 Eddie Bauer X 6.0
2005 Limited X 6.0
2008 F350 6.4
Yes it's true, I am the most interesting man in the world.
Dos X's!
Tom Doniphon is offline
