ats turbos?? - Ford Powerstroke Diesel Forum
Old 01-10-2009, 01:36 PM
ats turbos??
im looking into getting one of these turbos, not sure which one the 3000 or the 4000..hoping you guys have some info on them if anyone has used each one and what they think..its mostly a daily driver but in the summer ill take her to the drags.hoping you guys can help..
elliot
Old 01-10-2009, 02:30 PM
do you have any more mods or just whats in your sig. its not really worth it to upgrade your turbo unless you have more fuel. do you have studs? if not i would spend your money on that first. as for ats i havent used there products but they are quite pricey.
Old 01-10-2009, 08:01 PM
Illiana Chapter Director
elliot
I agree with motoxracer42. Need to stud that 6.0, delete the EGR and get more fuel. Personally, I would stay away from ATS. Heard too many things about their service after the sale if you have problems. Now there is a letter out there that supposedly they wrote but deny. I would check out Elites VGT-SS or talk to Industrial Injection for turbo upgrades but that is just my opinion.
Old 01-10-2009, 08:23 PM
Do you want a very quick spooling truck?
Old 01-11-2009, 01:10 PM
what about river city diesel turbos? and ive also been looking at injectors, would a need a bigger fuel pump to? not positive yet but looking at hving anywhere from 150mm to 180..and egr delete? what would a egr delete help me with?
Old 01-11-2009, 01:15 PM
EGR delete will keep you from flash boiling the coolant and either blowing the EGR cooler and or head gaskets. Haven't looked into River City Diesel so I can't tell you anything. With bigger injectors, I would look at going with an airdog or fass pump to help keep enough fuel supplied.
Old 01-11-2009, 01:21 PM
My turbo is from Josh and I have zero complaints about it and it was worth every penny of it.
Yes, your going to need a bigger pump. I have 150 injectors and it took 2 months before the stocker died on me. I would also suggest ITP's Fuel Regulated Return to help with the "dead-heading" issue that goes on with these trucks. Now the RR kit comes with a fuel psi gauge that attaches to the regulator itself, but I would get an in-cab fuel gauge as it was because of that I was able to know that my fuel pump was going out before it actually totally died on me.
Old 01-11-2009, 03:14 PM
what do you mean about the dead heading issue??
Old 01-11-2009, 03:33 PM
Not all the injectors get the same rate of fuel pressure with the stock system. A RR kit first off ramps up the fuel pressure(60 psi) and it delivers that to all the injectors.
Old 01-11-2009, 07:15 PM
Yup, it keeps the back injectors 5,6,7,8, from starving from fuel. The stock system bearly keeps up with stock injectors. I am in the process of becoming a vendor over here (just got responses from the email I sent) and hope to spend a little more time over here.
