Autometer Boost gauge - Ford Powerstroke Diesel Forum
Old 01-10-2009, 01:21 PM
Send a message via AIM to BLKF250
alright so i got my gauges put in a few days ago all of them work great besides the boost gauge, after about 10 pounds the needle starts to get jumpy i use silcone on all the fittings when i ran it to the map sensor and i use teflon tape on the fitting that goes on the back of the gauge..anyone got any ideas whats going on?
thanks
rob
Old 01-10-2009, 01:32 PM
If your intake is tapped, (the one in your sig should be), run your boost line to the intake and see if that doesn't take care of it.
Old 01-10-2009, 01:38 PM
yeah mine kinda does the same after 15 lbs, i ran mine to the map sensor and i just figured thats why it does it..ill probably sometime run it to my elbow.
elliot
Old 01-10-2009, 01:49 PM
a truck
I had mine in my map sensor and it jumped like that, when I put my IC on the hot pipe was tapped and I put the boost line in there and it fixed the jumping
Old 01-10-2009, 01:52 PM
my intake isnt tape but ill tape into it and run that boost line to it, that should make it more accurate right?i have a stock boost gauge one and its ok but i can already see the autometer is a couple more pounds accurate.but yeah when i a chance and not freezing outside ill get out on that
