My 6.0 doesn't whistle at all?? - Ford Powerstroke Diesel Forum
 3Likes
  • 3 Post By ZMANN
post #1 of 8 Old 06-10-2014, 07:33 PM Thread Starter
Alright so my 6.0 powerstroke won't whistle at all. It's got an 03 turbo and stage 2 batmowheel. 4 inch straight pipe into an 8 inch tip. How can I make it whistle?
May be a dumb question but I love the whistle these 6.0s give off
2004 king ranch 6.0
ARP HEAD STUDS
-EGR DELETE
-NEW OIL COOLER
-190cc INDUSTRIAL INJECTION INJECTORS
-03 TURBO with STAGE 2 BILLET BATMOWHEEL
-CAT COOLANT
-NEW GLOW PLUGS
-STAGE 5 SUNCOAST TRANSMISSION
-SRAIGHT PIPE
6ohstrokin is offline
post #2 of 8 Old 06-10-2014, 07:36 PM
JGman141's Avatar
Who's tuning are you running?
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 8 Old 06-10-2014, 07:37 PM Thread Starter
I just run the Scts pre made tunes
2004 king ranch 6.0
ARP HEAD STUDS
-EGR DELETE
-NEW OIL COOLER
-CAT COOLANT
-NEW GLOW PLUGS
-SRAIGHT PIPE
post #4 of 8 Old 06-10-2014, 07:39 PM
MWilbur516's Avatar
Sounds like your VGT isn't closing. What's your VGT duty cycle at idle and under power? Does the truck seem very laggy and smokey? Are you sure your VGT solenoid is plugged in?
Sent from AutoGuide.com App
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #5 of 8 Old 06-10-2014, 07:49 PM Thread Starter
Solenoids are good, im thinking maybe it's the tip, put a smaller tip on it or just cut the tip of to reduce the echo it's giving off now
2004 king ranch 6.0
ARP HEAD STUDS
-EGR DELETE
-NEW OIL COOLER
-CAT COOLANT
-NEW GLOW PLUGS
-SRAIGHT PIPE
post #6 of 8 Old 06-10-2014, 07:58 PM
JGman141's Avatar
It's not the tip, when is the last time you had the turbo off and cleaned?
JGman141 is offline
post #7 of 8 Old 06-10-2014, 07:59 PM
ZMANN's Avatar
Quoted: 1350 Post(s)
ODAWG714, MWilbur516 and LeeD13 like this.
We Miss you Ronnie
ZMANN is offline
post #8 of 8 Old 06-10-2014, 08:17 PM
MWilbur516's Avatar
There's only one solenoid. You didn't answer what the duty cycle was. It could also be the MAP line pulled off or a coked up turbine side causing the Vanes to stick. How are you sure it's none of these?
Also, how does the truck drive? Is it laggy, smokey? Did you install the 03' turbo and then noticed no whistle ?
