Powermax vs ATS Aurora 3000, currently have ATS but have a chance for a good deal on - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 34 Old 06-10-2014, 06:14 PM Thread Starter
j.mo's Avatar
Quoted: 1917 Post(s)
Wondering the differences or gains/losses in switching to a powermax?
Currently have the ATS aurora 3000 that came with the truck, but I'm looking for some more juice.
I just picked up an SCT tuner, so I may give it a shot and see what I can pump out of this ATS before upgrading.
What do you guys think? Can I squeeze some juice out of this ATS or just pick up a powermax?
64.7mm stg2 powermax
175/30 holders diesel injectors
WPE ported intake manifold
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
4" turbo back exhaust
Mishimoto intercooler/radiator/charge pipes
BPD 58v ficm
BPD HD cooler with filter relocation
7.3 fan clutch
Amsoil bypass
Leece-Neville 230a alternator
22x14 american force burnout
warren diesel trans
Yukon 4.56s and Truetrac
j.mo is offline
post #2 of 34 Old 06-10-2014, 07:49 PM
MWilbur516's Avatar
I think there are better options than the PMax, but I'd get a custom tune written for the ATS and run it before giving up on it. You could find that you like it. It's a small charger, but has a nice compressor map, so on a stock injector truck with intake , exhaust and tuner, it should run well.
Sent from AutoGuide.com App
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #3 of 34 Old 06-11-2014, 11:49 AM
What year is your truck? I have a brand new MTW stage 2 I need to get rid of. It won't work with my early '04. I'll give you an awesome deal on it if it'll work for your truck
CJR305 is offline
post #4 of 34 Old 06-11-2014, 11:49 AM Thread Starter
j.mo's Avatar
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
BPD 58v ficm
7.3 fan clutch
Amsoil bypass
warren diesel trans
j.mo is offline
post #5 of 34 Old 06-11-2014, 12:16 PM
Sent you a PM
CJR305 is offline
post #6 of 34 Old 06-11-2014, 05:20 PM
snafu!'s Avatar
Won't work or don't want to run it? Just curious.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #7 of 34 Old 06-11-2014, 08:30 PM
jmeaby's Avatar
Quoted: 16 Post(s)
I think you can get more ho out of the powermax. It's a bigger turbo. However the ats 3000 should have less lag. So even though the powermax flows more air you might not like the way it drives if that makes sense. Get a custom tune written for your ats but powermax gets my vote.
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #8 of 34 Old 06-12-2014, 05:00 AM
MWilbur516's Avatar
You must remember that a nonVGT turbo WILL ALWAYS out flow a VGT turbo on the top end and sometimes I'm the mid RPM's as well, even though the nonVGT may be smaller. Lately, companies like KC, Barder and VDP have been experimenting and building VGT's that level the playing field. Still, you'd be hard pressed to find anyone with even a little bit of knowledge about turbos that would claim in a side by side comparison, two like sized turbos (68's),one being VGT and one being nonVGT, would flow close to the same. The nonVGT always wins up top and the VGT wins down low.
In this case, I believe the ATS would out spool an out of the box PMax, but might be over taken by the PMax on the top simply due to size. The ATS is small. I'm not sure on its capabilities, but after a little research, it seems to be a stout turbo capable of 35 psi on a tuned, stock injectored truck. My vote still goes to getting a custom tune written for it and rolling with the ATS.
william_ace likes this.
post #9 of 34 Old 06-12-2014, 02:08 PM
jmeaby's Avatar
Quoted: 16 Post(s)
Matt thanks for that info. Why do non vgt turbos out flow up top I understand why 2 of the same sized turbos down low the but wins but why the non vgt up top. do the vanes not completely open even up top?
04 f250 cc sb.
jmeaby is offline
post #10 of 34 Old 06-12-2014, 03:25 PM
peixinho's Avatar
Quoted: 193 Post(s)
Well... the theory is that the vgt vanes get in the way of air flow up top in the rpm band.
but... I know I will get bashed for this... All the evidence shows that vgt turbo will flow the same as non-vgt turbos. People make similar power on dynos, tracks, and compressor maps say they flow the same... but everyone talks about non-vgt turbos flowing more up top.
The theory makes sense but I have not seen any data to support the subject.
I would put my KC 68mm stage 3 turbo up against any 67.7 FMW on similar trucks any day of the week... Not saying that I would win, but it would be cool to see what happens.
jmeaby likes this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
