Started the QUEST mo pow. - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By JGman141
post #1 of 8 Old 06-08-2014, 06:58 PM Thread Starter
mossyoak's Avatar
Finally decided on 190cc injectors. Now trying to decide on which nozzles 75% or 100%. I have a powermax stage 2. I also will be upgrading the fuel system soon, but for now going to stay stock. I will be putting in a new hpop since mine has 250k on it. So my question is what would be the difference in the two nozzles, and what numbers should I expect with the setup. I run the Looney extreme, and also have tony's tunes too. What other good tunes are out there for the pomax and these injectors. Thanks in advance.also I'm sending off the FICM for the atlas 40 or 80 can't make up the noggin on that one either.
all the bullet proof things done, cat antifreeze, stock sticks, powermax / batmowheel, Tony Wildman tunes.
mossyoak is offline
post #2 of 8 Old 06-09-2014, 05:44 AM
william_ace's Avatar
Quoted: 2 Post(s)
What are the specs on your powermax stage 2? I think it all depends on what you want. I went with 100% nozzles due to the fact that the tuner I use really likes them. A 75% nozzle in theory should run a little cooler when you tow. Who's injectors are you going to run?
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #3 of 8 Old 06-09-2014, 06:56 AM
6 L chevy eater's Avatar
id do the 75 nozzles if i were you. they will still flow all the fuel on a race tune. just my opinion .
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #4 of 8 Old 06-09-2014, 07:28 AM Thread Starter
mossyoak's Avatar
This is the specs on the turbo
Compressor Wheel Inducer: 63.5mm
Compressor Wheel Exducer: 88mm
Compressor Wheel Trim: 52
Turbine Wheel Inducer: 72.5mm
Turbine Wheel Exducer: 66.5mm
Turbin Wheel Trim: 84
Turbine Housing: .90
Turbine Vanes: Altered for Higher Flow
It has the bat wheel in it also.
mossyoak is offline
post #5 of 8 Old 06-09-2014, 07:50 AM
JGman141's Avatar
Your going to need more air than that turbo can push to clean up 190s. As far as nozzles go I'd do the 75% because they can flow around 240cc of fuel which is more than enough.
william_ace likes this.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #6 of 8 Old 06-09-2014, 07:52 AM Thread Starter
mossyoak's Avatar
So can a tuner keep me happy with the 190's 75? Until I can get my spare turbo built for them.
mossyoak is offline
post #7 of 8 Old 06-09-2014, 08:05 AM
peixinho's Avatar
Quoted: 231 Post(s)
You should be fine as long as your turner pulls a little fuel... that should hold you over until you get a bigger turbo
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is online now
post #8 of 8 Old 06-09-2014, 08:06 AM
peixinho's Avatar
Quoted: 231 Post(s)
Sounds like you just have a standard pmax with a batmowheel. Should be ok for 175s but will run pretty smokey on 190s
KC Turbos
