turbonetics fixed geometry turbo... thoughts? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-07-2014, 04:42 AM Thread Starter
livinlots26's Avatar
So I found this turbonetics turbo the inlet is 58/71 74 .59 A/R. Just wondering if anyone has any input on this turbo. Right now I have a powermax with a mtw single plane wheel. I'm using 175 injectors and have a gogo diesel ported intake. As well as other things here and there. My question is how well will these injectors handle this turbo, right now I can light up the power max quick as hell but I'm lacking top end power, and what would the drivabilty be? I use this truck for everything and just don't want to lose function over form.
4 inch down pipe 5 inch stacks no cat, Powermax turbo, CFM large mouth intake elbow with larger pipe, S&B cold air intake, Edge juice with attitude CS with custom PHP tune. Atlas 80 ficm tune. Airdog2, TRP sump, 6.4 banjo bolts, Blue spring, Zoodad mod, Traction bars, counter sunk tool box molded around my stacks made by me, Coolant filter, ARP head studs, southbend duel friction clutch, complete EGR delete, DP mod, high idle mod, CCV relocation, 35 inch fierce attitude tires on 17" helo wheels
livinlots26 is offline
post #2 of 6 Old 06-07-2014, 04:45 AM
6 L chevy eater's Avatar
LOOK into a KC turbo....... WPE diesel.com. or PM charlie or nate. They will get u hooked up
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #3 of 6 Old 06-07-2014, 12:39 PM Thread Starter
Charlie fish?
post #4 of 6 Old 06-07-2014, 12:50 PM
william_ace's Avatar
Quoted: 2 Post(s)
Yes. Mr. Fish.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #5 of 6 Old 06-08-2014, 06:38 AM Thread Starter
The main reason I'm debating this turbo is cause a guy has it for sale not far from me.
post #6 of 6 Old 06-08-2014, 04:30 PM
peixinho's Avatar
Quoted: 176 Post(s)
I would personally pass on the deal... even if it was free. Your pmax is a 63.5mm turbo and this is a 58mm turbo. That is smaller than stock 2004 turbos and much smaller than your pmax. You will more than likely end up with less power and slower spooling than your current setup. Your 175s are gonna way over fuel the 58mm
Here are a couple links to what I found out
Need opinion on a turbo
Turbonetics Stage 1 6.0L
Turbonetics Stage1 6.0L - PowerStrokeNation : Ford Powerstroke Diesel Forum
turbonetics 58mm stock replacement - TheDieselGarage.com
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
