Gearhead Tunes - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 37 Old 06-04-2014, 11:06 PM Thread Starter
trophy_23's Avatar
Gearhead Tunes
Am looking at tunes for the first time and I am considering the 3pack from Gearhead. SRL or SRL+, 8K Tow, Unlimited tow. I am mostly using the truck as a daily driver, with the odd tow under 6k lbs, what exactly is the difference between the SRL/SRL+? The truck is now studded and deleted.
Also, can you tow with the SRL at all? If not, would it be ok just to haul a 5000lb boat out of the water with SRL or would you need to switch to a tow tune? Hopefully these aren't stupid questions!
Thanks in advance
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
trophy_23 is offline
post #2 of 37 Old 06-05-2014, 02:12 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
The plus on the SRL is a tad more timing and I believe tad more boost.
I'm sure you could tow with SRL but watch those EGTs.
Gearheads makes some nice safe tunes.
MrOneEyedBoh is offline
post #3 of 37 Old 06-05-2014, 02:18 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Pulling a 5k boat out of the water shouldn't be an issue in SRL as long as you drive rationally
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 37 Old 06-05-2014, 02:41 AM
strokersixo's Avatar
Quoted: 32 Post(s)
Thanks in advance
I don't see in your Sig whether you're studded or not. If you're not studded, IMHO I wouldn't risk hauling a 5000lb with SRL, that is you want to blow your head gaskets, be on the safe side and load a tow Tune that modifies the tranny shift points.
Sent from tapatalk PRO ........ I WISH
--MAX--
strokersixo is offline
post #5 of 37 Old 06-05-2014, 04:56 AM Thread Starter
trophy_23's Avatar
The truck is in for studs right now, havent updated sig yet. I am not looking to tow long distance on SRL, mostly wondering if I'd have to change tunes just to drag a 6k boat up the boat ramp out of the water 100ft? I will be getting some tow tunes as well for if I had to go any distance. My main question though is for a mostly daily driver is SRL the way to go? Or better with studs to go for SRL+? Is it a huge difference, I am wanting some better mpg, good shifts and just general good driveability.
High Idle
Duraflaps
Dually ID Bar
post #6 of 37 Old 06-05-2014, 05:37 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Pulling a boat out of the lake should be perfectly fine. Ive hauled 13k for 200 miles in it. Although I by no means recommend it. I know the risks
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 37 Old 06-05-2014, 05:42 AM Thread Starter
trophy_23's Avatar
Thanks! I see you have the PMM coolant filter, are you happy with? That is the next thing I will be adding once funds recover a little bit!
High Idle
Duraflaps
Dually ID Bar
post #8 of 37 Old 06-05-2014, 05:45 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
It does the job. But PMMs business practices have gone sour since I got it. Id recommend getting one elsewhere
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #9 of 37 Old 06-05-2014, 05:49 AM Thread Starter
trophy_23's Avatar
Oh I wasn't aware of that. I have also looked at Sinister and Dieselsite. I like PMM's hoses, other than the blue!
High Idle
Duraflaps
Dually ID Bar
post #10 of 37 Old 06-05-2014, 10:12 AM
D_L
great tunes, Good People...
07 F-250 6.0L Lariat Outlaw, Weaver Performance, Stage III Mad Turbo Werks (Adrian), (IDP, TSD, Gearhead Tunes), 155/30 cc Warren Injectors, Andy Warren/A1 Performance tranny, PI 1800 rpm Stall Converter, Strictly Diesel Regulated Fuel Return, Absolute Performance Ported intake, Moto Metal MO961 20x9 whe els, 295/60R20 Terra Grapplers, etc.
D_L is offline
