EGT HELP - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 39 Old 06-04-2014, 05:46 AM Thread Starter
jensenrcng's Avatar
Quoted: 2 Post(s)
EGT HELP
Will bad injectors cause high EGTs? I have to drive by EGTs. Shop told me I have 4-6 injectors in various stages of bad. (New Warrens have been ordered) I just do not want to burn up my truck.
2015 F-250 4x4: SCT X4 Tuner, Custom Rowdy Racks Tunes, 5" Exhaust, S&B intake, H&S Intercooler Pipe, AMP Research Steps, Carli 4.5" Pintop w/Full Rear Deaver Springs, ICON Dual sterring Stabilizer, 18" BMF Black/Machined Novakanes w/ 37x13.50 TOYO MT, Mishimoto Aluminum Radiator & Thermostat, Driven Diesel Oil Pan, Mag-Hytec trans pan and rear dif, T-Rex Black Billet Grille
jensenrcng is offline
post #2 of 39 Old 06-04-2014, 05:54 AM
Heavy_GD's Avatar
Quoted: 1424 Post(s)
Feedback Score: 3 reviews
what are your egts?
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #3 of 39 Old 06-04-2014, 05:59 AM Thread Starter
jensenrcng's Avatar
Quoted: 2 Post(s)
70 mph on the highway it will cruise at 10-1100 Easily. But if I feather the gas and keep my foot out of it I can get it down to 8-900. If I give it gas to pass anybody it'll hit 12-1300 easily.
post #4 of 39 Old 06-04-2014, 06:03 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
THose temps arent gonna hurt you. When pulling the camper in the summer down the highway in 100*+ temps 1000* egt's were the norm. Sure I would like to see less, but with our altitude here we just dont have any air to work with. I think a aftermarket turbo and/or water injection is about my only options.
peixinho likes this.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 39 Old 06-04-2014, 06:05 AM
Heavy_GD's Avatar
sounds like the temps when I had a boost leak.
GD
post #6 of 39 Old 06-04-2014, 06:08 AM Thread Starter
jensenrcng's Avatar
Quoted: 2 Post(s)
Those are the temps with no load. I'm in Phoenix and it's 100+ degrees every day but it doesn't matter if it's 75 or 100 my egts don't change. I have stage two Turbo on mine and 155 Injectors that are bad.
post #7 of 39 Old 06-04-2014, 06:10 AM Thread Starter
jensenrcng's Avatar
Quoted: 2 Post(s)
How big of a Boost leak do you need to make those temps?
post #8 of 39 Old 06-04-2014, 06:12 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Your runnin hot but just be easy with it. Are you letting the truck cool before shutting it down? I had to switch my turbo timer over to the time mode when the warrmer temps got around. The egts wouldnt cool enough to trip my temp mode.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 39 Old 06-04-2014, 06:15 AM Thread Starter
jensenrcng's Avatar
Quoted: 2 Post(s)
Yes I let it cool down to around 400 for I shut the truck off. I'm driving like a grandma on Sunday.
post #10 of 39 Old 06-04-2014, 07:28 AM
peixinho's Avatar
Quoted: 193 Post(s)
When did the problem start?
What were your egts before?
What size nozzles do you have? 155/stock 155/30???
Are you on stock gearing?
A stage 2 turbo, with 155cc injectors, 37" tires, stock gearing, and the hot AZ weather is going to result in higher temps. I would say 800-900 would be average for that type of setup... maybe 750-850 with the extra air flow mods you have. Probably hit 1100-1200 on a 50% throttle acceleration.
Even the slightest boost leak can cause a change in egts. Small leaks usually dont stay small for long because the pressure usually makes the whole/crack/gash get bigger when pressure is rushing through it.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
