TURBO HELP - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-03-2014, 10:14 AM Thread Starter
2003powerstrokef250's Avatar
TURBO HELP
I'm currently looking an investing in a new turbo. I still have stock sticks and am bulletproofed. I was told get the powermax but was also told to look at Barder and mad turbo werks for turbo also. If anyone couldn't add some insight to put me in the right direction that would be great
2003 powerstroke
ARP headstuds
MBRP 4" straight pipe
Banks ram air intake
Glowshift gauges
Zoodad mod
High idle mod
Sinister EGR Delete
New Ford Headgaskets+oil cooler
Sinister Coolant Filtration
Sct sf3 tuned by matt and eric
2003powerstrokef250 is offline
post #2 of 14 Old 06-03-2014, 01:12 PM
Marine Raiders>Seals
najaf4life's Avatar
What is your end goal?
I would look into WPE/KC turbos.
RYAN
03 Excursion 6.0L
BPD,WPE & other odds and ends
najaf4life is offline
post #3 of 14 Old 06-03-2014, 01:19 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Considering that you have an 03 truck, if you have no desire to go bigger on your injectors, then I would recommend a new Powermax with a billet wheel and call it a day. A lot of guys don't like the so called lag associated with the Powermax, but considering that it has the same turbine wheel as your stock turbo, your tuning will already be set up for it and you shouldn't have any of these side effects.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 14 Old 06-03-2014, 02:09 PM
peixinho's Avatar
Quoted: 191 Post(s)
I agree with Ryan... A lot will come down to your end goal. It depends on what you are planning on doing with the truck and what you want out of your new turbo.
Quicker spool?
More Power?
Heavy towing?
Racing?
I think a stage 1.5 or stage 2 turbo would suit you well
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is online now
post #5 of 14 Old 06-04-2014, 04:48 AM Thread Starter
Does the stage 1.5 hard to install? Or is it literally just take out the old turbo and install the new parts?
2003 powerstroke
ARP headstuds
Glowshift gauges
Zoodad mod
High idle mod
Sinister EGR Delete
post #6 of 14 Old 06-04-2014, 05:21 AM
BACKYARDIGAN
Quoted: 4 Post(s)
Any VGT turbo option is drop in and go.
I still think that since you already have an 03 that there's not going to be any monumental difference between a 1.5 or a Powermax with a billet wheel if both turbos have the same turbine wheel. Either way you go should work out good.
Nate
post #7 of 14 Old 06-04-2014, 08:10 AM Thread Starter
[QUOTE=windrunner408;9297946]Any VGT turbo option is drop in and go.
I still think that since you already have an 03 that there's not going to be any monumental difference between a 1.5 or a Powermax with a billet wheel if both turbos have the same turbine wheel. Either way you go should work out good.[/
Is the billet wheel a must have? Or can I do without it?
2003 powerstroke
ARP headstuds
Glowshift gauges
Zoodad mod
High idle mod
Sinister EGR Delete
post #8 of 14 Old 06-04-2014, 08:13 AM
BACKYARDIGAN
Quoted: 4 Post(s)
IMO, the billet wheel is a must have.
Nate
post #9 of 14 Old 06-04-2014, 08:14 AM
peixinho's Avatar
Quoted: 191 Post(s)
I would rebuild the turbo you have and put a billet wheel in it before I would go and buy a powermax and keep the cast wheel...
Do your research and you will see that the powermax with just the cast wheel is not a very good option. Make sure to put a billet wheel in it or just go with a stage 2 turbo.
You never answered the previous questions....
Quicker spool?
More Power?
Heavy towing?
Racing?
KC Turbos
post #10 of 14 Old 06-04-2014, 08:19 AM
BACKYARDIGAN
Quoted: 4 Post(s)
Quicker spool?
More Power?
Heavy towing?
Racing?
TOTALLY AGREE HERE...
NO CAST WHEELS... BILLET FTMFW
The ultimate option IMO is to send in your 03 turbo and have KC rebuild it to a Stage 1.5/2. Trust me, there's no finer rebuilding process that your turbo can go through. You'll have an awesome performing turbo and it will be stood behind better than what you could get with a Powermax.
Nate
