SCT X4 question... - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-01-2014, 12:36 PM Thread Starter
jlmotox's Avatar
SCT X4 question...
I got a sct x4 and using the setting on toyo's website for my 37" tires it shows to use 560 revs per mile. I set that and my gear ratio for the engine tuning and then before going to the transmission tuning the tuner asks "have you changed your tire size?" And has a list of settings 600 to 700??? If I check off "no I have not changed my tire size" my speedo is off about 10mph at highway speeds... If I set to the lowest number "600" it's off about 4-5mph at highway speed...Am I doing something wrong?? The second main reason I bought the tuner was to make my speedo correct...first reason was for the fun added to the skinny pedal. Lol
Will a "custom" tune fix this or did I miss something?
Thanks guys!
Sent from AutoGuide.com App
2005 F250 Lariet FX4 CC SB 6.0, 6" ProComp Stage2 Lift,17x9 ProComp wheels,35" ProComp xtreme AT's,Warn 12k winch w/hidden kit,Custom light bar w/4-8" ProComp,Pioneer double din Nav XM back up cam,10" kicker sub,1000w 5channel amp,15% tint, Truxedo bed cover,Firestone Bags,Airaid intake,4" turbo back MBRP exhaust,ARP headstuds
jlmotox is offline
post #2 of 12 Old 06-01-2014, 01:12 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I'm not sure if a custom tune will correct that or not, but yes the lowest rev/mile that you can set it to is 600. The only other way to get that back is to physically change your axle gear ratio (if the custom tune won't fix it). Everything you did was right.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 12 Old 06-03-2014, 05:14 PM Thread Starter
jlmotox's Avatar
Thanks for your reply!
Another couple questions I have...
What benefit does "lock torque converter in 1,2,3" do?
Also does the "jake brake" option only work while in tow/haul?
So far I'm liking the Sct! Running the "street" tune now and it runs nice!
Can anyone compare the "street" tune to the gearhead SRL?
jlmotox is offline
post #4 of 12 Old 06-03-2014, 05:59 PM
ZMANN's Avatar
Quoted: 1344 Post(s)
the gear ratio does not effect the speedometer since the sensor is after the ring only tire size effect the speedometer
We Miss you Ronnie
ZMANN is offline
post #5 of 12 Old 06-03-2014, 06:30 PM
i just bought the same tuner but i am running into a different problem. I recently had the edge evolution and extreme she was nasty but on performance on my X4 its no where near the amount of power that the edge put out.
Am i doing anything wrong?
I noticed the have a shifting gain thing and it goes up 7mph or -7mph or something like that. whats that about??
TMowery77 is offline
post #6 of 12 Old 06-03-2014, 06:35 PM
ZMANN's Avatar
you need a custom tune
I also had the edge and I just loved it specially the shift on the fly
but to many reports on the tranny issue had me go to the SCT and then to custom tunes
We Miss you Ronnie
ZMANN is offline
post #7 of 12 Old 06-03-2014, 06:43 PM
Is the xtreme x 190rewhp from innovative worth it?
post #8 of 12 Old 06-03-2014, 06:49 PM
ZMANN's Avatar
i tried a few tuners
I like Gearheads and Wildman
I have innovative also but didn't like the service after the sale or the absolute lack of it
so after a week i bought some from Matt and never looked back
you can play with the shifting even on a custom tune make sure you keep notes so you can keep track of changes
We Miss you Ronnie
ZMANN is offline
post #9 of 12 Old 06-03-2014, 06:50 PM
thanks for the replies man! will the custom tunes wake up the sct like the edge was?
post #10 of 12 Old 06-03-2014, 06:53 PM
ZMANN's Avatar
i really had my edge tweaked in the back menus it was fast but I did not have the Hot unlock option
i never felt my custom tunes were exactly the same power wise down low but they are all around better and less smokey
We Miss you Ronnie
ZMANN is offline
