Build advice - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By 6literdiesel
post #1 of 6 Old 05-30-2014, 06:41 PM Thread Starter
loganjj27's Avatar
Build advice
Hey guys I'm starting a build for a buddy this week and just looking to get some advice on everything. Just wanna make sure it sounds like a good set up and I'm not forgetting anything. Here's what I got so far. ARP studs, OEM gaskets, oil cooler, warren 175/75 injectors with drivin diesel RR. Should regulated return be enough to support these injectors? MTW Madmax turbo, standpipes and dummy plugs. Egr is already deleted. HD up-pipes, FICM rebuild with either atlas 40 or 80 tune along with gear head tunes, sinister coolant filter, and that's all I remember for now. Gonna have an extra grand to play with so should I go for banks technicooler kit, ported and polished intake, or what? Love to hear from the pros. Thanks guys.
Logan Johnston
Sales Associate
Rudy's Diesel Performance
1404 Christian Ave.
Durham, NC, 27705
loganjj27 is offline
post #2 of 6 Old 05-30-2014, 11:18 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
Build advice
175/75 and RR will depend on the health of the HFCM and tune PW used. A full fuel PW tune might starve the injectors to support the fuel volume and psi needed to support 175/75 if the HFCM is weak.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 6 Old 05-31-2014, 12:34 AM Thread Starter
loganjj27's Avatar
OK so what would you recommend to prevent starving? Maybe a dumb question but everybody says fass and airdog have a lot of failures so I'm not sure what to use.
Logan Johnston
Sales Associate
1404 Christian Ave.
Durham, NC, 27705
post #4 of 6 Old 05-31-2014, 02:33 AM
Quoted: 8 Post(s)
It's the Airdog II units that people are having issues with, the "standard" Airdogs have a good reputation. You could also put a 6.4 fuel pump between the tank and the stock 6.0 pump. People are having good luck with this when you add a sump as well. For the extra $1,000 I'd suggest putting if toward an intake manifold.
william_ace likes this.
2005 Excursion Lariat 4x4
Mishimoto coolant filter, RCD EGR delete, '03 turbo w/ single plane billet compressor wheel, Edge CTS w/ EGT probe, 5" Rough County suspension, Hellwig 32mm sway bar, 35x12.50 Toyo M/T, 20x12 Fuel Renegade D263 wheels
Originally Posted by F450Harley View Post
I really believe these trucks have adaptive behaviors to your driving habits. Your truck reflects you.
If you think your truck might let you down…………..it WILL.
6literdiesel is offline
post #5 of 6 Old 05-31-2014, 06:21 AM Thread Starter
loganjj27's Avatar
So can the original airdog still be purchased or have they been replaced with the airdog 2?
Logan Johnston
Sales Associate
1404 Christian Ave.
Durham, NC, 27705
post #6 of 6 Old 05-31-2014, 06:47 AM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Yes, original AirDog and others will work as a feeder pump only. These pump are low psi pumps (about 10 psi) high volume. You would use this style pump to feed the stock HFCM.
The 6.0 requires a high psi high volume pump (50+ psi) to supply the injectors.
Link below, start at post #11, has info with links to help answer your question.
New gauges today
Lilpooh is offline
