Colt cams? - Ford Powerstroke Diesel Forum
post #1 of 29 Old 05-30-2014, 03:39 PM Thread Starter
Colt cams?
I was reading the dp mag and saw the colt cams, claim to improve everything, any feedback on these?
STECKSTROKE1999 is offline
post #2 of 29 Old 05-31-2014, 01:25 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 132 Post(s)
Feedback Score: 3 reviews
It's been said that a Stage 1 works pretty good, but after that there's LOTS to do inside the motor to make it all come together. It's my understanding the Stage 1 is mild which helps it work on a "stock" motor.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 29 Old 05-31-2014, 06:16 PM
RCD recommends flycutting the pistons for a stage 2, but if y'all saw my thread a couple weeks ago a guy on here said he had a stage 2 and didn't have to flycut the pistons, I dunno though.
Sent from AutoGuide.com App
DieselEnthusiast is offline
post #4 of 29 Old 06-02-2014, 05:48 AM
Chatham036's Avatar
Quoted: 136 Post(s)
Stage 1 & 2 colt cams do not require any piston modification. Stages 3 & 4 do require cutting.
I am pretty happy with my choice to run a stage 1 cam. I did a lot of changes when I swapped cams so I cant really tell you how much difference was made, but the truck does haul ***.
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
The Following User Says Thank You to Chatham036 For This Useful Post:
Heavy_GD (06-02-2014)
post #5 of 29 Old 06-02-2014, 10:03 AM
borsky4's Avatar
Basically if your doing an engine build put one in, if not the juice probably isn't worth the squeeze. I am happy with mine I noticed a lot cooler cruising egt's, I did other mods at the same time so it's tough to tell how much power or mileage it added but I'm sure the cooler cruising egt's is a lot to do with the cam. It helps spool the turbo too, some guys say it only helps spool non vgt's but that doesn't make sense to me if it helps spool a non vgt it help spool a vgt with less back pressure then without, especially if your running a big vgt.
2006 CC SB, SRW, Barder stg #2, Ported manifold, Warren 190 30's, banks CAC, SCT Tuned by/IDP, IDP ficm tunes, nadp trans, fluidampr, FASS LP, Driven RR, edge insight, HPODS, BD ex manifolds, HD y pipe all ceramic coated & wrapped, UCF O-ringed heads with arp's, Colt stg 1 cam with RCD springs and tubes,
6" lift/trac bars, 37's 4:30 gears, Future mods: non VGT T4 64mm BASB
borsky4 is offline
post #6 of 29 Old 06-02-2014, 03:02 PM
I'm sure I'm missing something here, but if no piston work is needed for a stage 2 what made y'all go with a stage 1 instead of a stage 2 if they're both drop in cams.
post #7 of 29 Old 06-02-2014, 03:19 PM Thread Starter
stage 1 is a reground stock cam and stage 2 is a new billet, they are both the same grind, but stage 1 is 300$ less.
2006 ccsb f 250 king ranch
3" rough country lift
20x10 chrome fuel hostage
35x12.50 toyo m/t
2008 tailgate with step
window tint
egr delete
4" mbrp straightpipe
sct tuner
innovative custom tunes: econ, 65 tow, 120 street
oricle halos
firestone airbags and compressor
more to come...
106k and counting
"Diesel mechanics have bigger tools"
post #8 of 29 Old 06-02-2014, 03:21 PM Thread Starter
im thinking about doing studs, how much more would I have to tear into it to get the cams out?
35x12.50 toyo m/t
window tint
egr delete
sct tuner
oricle halos
more to come...
106k and counting
post #9 of 29 Old 06-02-2014, 03:46 PM
borsky4's Avatar
I went with the stage one because of the fact the regrind relieves a little bit of lifter preload and cheaper. but with shipping the core not as much. Also the stage 2 has slightly more exhaust duration, this is because the regrind limits what can be done, where as with a new billet you are starting with a blank canvas. But basically the same cam give or take.
borsky4 is offline
post #10 of 29 Old 06-02-2014, 03:47 PM
borsky4's Avatar
Pull engine, pull crank, change cam. Put it back together...
borsky4 is offline
