03 Intake modification? - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By HeavyAssault
  • 1 Post By lenzhotrod
post #1 of 4 Old 05-30-2014, 02:31 PM Thread Starter
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
I have my intake off for various reasons, and while its off I was gonna have it hot tanked and was debating having the connector across the back removed.
My questions are... Is it worth it? Has anyone seen any performance gains from doing this? Is easier access to the HPOP the only reason for this? And if it is, I guess the EGR cooler can come out w/o removing the intake?? Because accessing the HPOP, from I can tell, can still only be done with the EGR cooler removed. (For reference, I have Bulletproof Diesel's EGR Delete). Thanks for the input.
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #2 of 4 Old 05-31-2014, 01:28 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 132 Post(s)
Feedback Score: 3 reviews
It can be cut out with no issues down the road. Plenty of people have modded a 2003 manifold for use on the 2004-2007 trucks. I'd suggest getting a competent shop that knows how to weld aluminum. Additionally the heat from welding could cause the manifold to warp causing sealing issues so ensure it's bolted down as if it were installed when they do the work.
william_ace likes this.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 4 Old 06-01-2014, 07:50 AM
Quoted: 15 Post(s)
The 03 manifold can be a pain to work around but I like the fact that it balances the rear cylinders and help with slowing any warping that may occur.
ODAWG714 likes this.
lenzhotrod is offline
The Following User Says Thank You to lenzhotrod For This Useful Post:
ODAWG714 (06-01-2014)
post #4 of 4 Old 06-01-2014, 09:41 AM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
I agree ^^
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
