Fuel Pump Question
I found a guy selling a brand new Raptor RP-150 Pump and he says it's for a ford, but when i was looking for them the only one i could find for the ford was the RP-100, will this 150 pump work on my truck ??
Anyone know if i can run the 150 pump, even though i only need the 100 cause i can get a good deal on this pump
yes you can. I talked to pure flow about this pump becuase i plan to run the same thing. If you are running the pump you have to run it with your stock mechanical pump. The raptor is only a lift pump and does not have enough PSI to run by itself so all it is doing is helping your stock pump so it doesnt have to work near as hard. Keep in mind though with the raptor you have to run 1/2 inch lines
