Exhaust backpressure gauge - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-30-2014, 06:27 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
I would like to read exhaust back pressure,with my truck being and 04 it does not read correctly on the cts.I have a fitting in my up pipe ,but I thought I remember reading that the sensor would not be able to handle the heat.Is there any truth to this ? For those with 04s and back , are you tapping into the exhaust
sensor tube?
Thanks
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #2 of 10 Old 05-30-2014, 06:50 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
From your up-pipe, you run a length of metal tubing (cooper or stainless) away from up-pipe, then coil the tubing to a fitting that accepts the sensor. Almost like the factory sensor, keeps the sensor away from direct heat.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 10 Old 05-30-2014, 07:09 AM
Powerstroke Techie
Lilpooh's Avatar
Robert, in this link you will get the idea.
http://www.dieselmanor.com/dm_products/DM-EGT25125.asp
Lilpooh is offline
post #4 of 10 Old 05-30-2014, 10:18 AM
snafu!'s Avatar
JGS makes a particle trap for to keep the sensor clean and adds an extra port. I'm planning on running one with SS tubing with an edge sensor on the CTS.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #5 of 10 Old 05-30-2014, 05:09 PM
bondajb's Avatar
Early models used 1/8 npt.. I used a 2" brass riser and then a T.. for my sending unit and the ebp sensor.. nor much difference between the two sensors other than the range...
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #6 of 10 Old 05-31-2014, 01:16 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Originally Posted by Lilpooh View Post
Thanks,Rich that's what I was looking for.
post #7 of 10 Old 05-31-2014, 04:41 AM
strokin6L's Avatar
Quoted: 4 Post(s)
I T off the ebp sensor. Gonna wanna make a filter of some sort so your sensor doesn't get plugged with carbon. Once it starts to get plugged....you'll have incorrect readings.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #8 of 10 Old 05-31-2014, 05:09 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I've had my glow shift max tow 0-60 psi boost gauge rigged up to read EBP now for over a year and all I did was I cut about 1.5-2 inches out of the stock EBP sensing line, then put a brass compression T fitting to take up the gap, then I used the short piece I cut with another brass compression adapter to adapt it to 1/8 npt. It was super simple and works awesome so far. I don't have any heat or particulate issues.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 10 Old 05-31-2014, 05:30 AM
strokin6L's Avatar
Quoted: 4 Post(s)
Here's what I did.
post #10 of 10 Old 05-31-2014, 05:42 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Thanks for the info.i still need to figure out which setup I am going to use.I have the cts but if I use it ,I will have to buy the expansion accessories and sensors or I can get new gauges.
