New to me 06 f350 - shooting for 550-600whp what's needed? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-29-2014, 07:53 PM Thread Starter
j.mo's Avatar
Quoted: 1965 Post(s)
Picked up a new to me 06 f350 today. Has quite a bit of work done already.
It's going to be on 37s as soon as my wheel/tire package shows up, and I'm shooting for 550-600whp. What turbo should I go with to start achieving this goal?
j.mo is offline
post #2 of 14 Old 05-29-2014, 08:03 PM
JGman141's Avatar
What mods does the truck have? Sct tuner? Exhaust? Studs?
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 14 Old 05-29-2014, 08:08 PM Thread Starter
j.mo's Avatar
No tuner. Truck is studded, egr cooler, ordering a sinister oil cooler and coolant filter.
Afe intake, 4" mbrp, aurora turbo, Afe charge pipe, oil filter relocation.
I know I'm forgetting things
This is all new to me. I have a built silverado 1500, but have been out of the diesel scene for quite some years, I've had 2 6.0s but never any engine work dome to them.
j.mo is offline
post #4 of 14 Old 05-29-2014, 08:10 PM
john galt's Avatar
Quoted: 1215 Post(s)
congrats and welcome to the addiction
you should be able to hit your goal with injectors exhaust and turbo. there are LOTS of threads dedicated to that purpose.
not sure what is done already but if you dont have a monitor that would be first on my list and you will want to look into building your trans as well at that level of power
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is online now
post #5 of 14 Old 05-29-2014, 08:12 PM
peixinho's Avatar
Quoted: 207 Post(s)
Welcome to the sight... You have come to the right place to learn all about your truck. Excuse me if you have heard all this before but I am assuming you are new to the 6.0 powerstokre world because you just joined.
Have you done all the typical bullet proof stuff: EGR delete, head gaskets, studs, oil cooler, updates, etc...
Also do you have a good monitoring system? Like gauges, edge cts, or livewire. It is very important to monitor everything but most importantly EOT, ECT, EGT, Fuel pressure, Tranny temps, etc...
Then the very next thing that would be on my list is gears. It will be a great investment. You want your rpms to close to a stock ration (especially when going with a larger turbo). 37" tires on stock gearing will make a big turbo feel super laggy and lug the motor.
After 500hp I would start planning for a tranny. Some people have good luck for a little while but most people eventually blow up the tranny once they start to venture past 500hp.
A fuel system is also a very good idea. I know a bunch of people running stock fuel on 175s and 190s with no problems... but they are walking on thin ice.
After all that... Warren 190/75s with long side solenoid upgrade and a KC 68mm stage 3 turbo has shown to be a great way to make 600hp
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #6 of 14 Old 05-29-2014, 08:13 PM Thread Starter
j.mo's Avatar
I've been told to look into the garret powermax? It has turbo back exhaust already, and all monitoring gauges in place. I'll get some pictures of the engine bay and more specifics tomorrow.
My gasser is built and done, gonna turn that over to the gf and start another project
j.mo is offline
post #7 of 14 Old 05-29-2014, 08:18 PM
JGman141's Avatar
The powermax isn't much of an upgrade over the stock turbo, there are many vendors out there now such as kc, barder, mtw, and many more. It all comes down to what you want and what you think is the best option. I also agree that you should look into gears if you want to run 37s
JGman141 is offline
post #8 of 14 Old 05-29-2014, 08:33 PM Thread Starter
j.mo's Avatar
What's the most power I can push without venturing into injectors?
j.mo is offline
post #9 of 14 Old 05-29-2014, 08:46 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
400-450hp, with SCT tuner. depending on the health of motor, custom tune, and PCM strategy.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #10 of 14 Old 05-30-2014, 05:47 AM Thread Starter
j.mo's Avatar
What would I net with a powermax on it?
64.7mm stg2 powermax
175/30 holders diesel injectors
WPE ported intake manifold
Airdog 165 4G
Beans sump
O-ringed UCF heads
H-11 headstuds
4" turbo back exhaust
Mishimoto intercooler/radiator/charge pipes
BPD 58v ficm
BPD HD cooler with filter relocation
7.3 fan clutch
Amsoil bypass
Leece-Neville 230a alternator
22x14 american force burnout
warren diesel trans
Yukon 4.56s and Truetrac
j.mo is offline
