Ptp turbos - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By JGman141
  • 2 Post By white59rt
post #1 of 5 Old 05-29-2014, 05:52 PM Thread Starter
borsky4's Avatar
Ptp turbos
Garrett | 772441-5001s-M | PowerMax Modified Turbo 04.5-07 6.0L
Anyone running one of these? They claim there cast 66 outflows the competitions 68mm
2006 CC SB, SRW, Barder stg #2, Ported manifold, Warren 190 30's, banks CAC, SCT Tuned by/IDP, IDP ficm tunes, nadp trans, fluidampr, FASS LP, Driven RR, edge insight, HPODS, BD ex manifolds, HD y pipe all ceramic coated & wrapped, UCF O-ringed heads with arp's, Colt stg 1 cam with RCD springs and tubes,
6" lift/trac bars, 37's 4:30 gears, Future mods: non VGT T4 64mm BASB
borsky4 is offline
post #2 of 5 Old 05-29-2014, 06:09 PM
JGman141's Avatar
The only 68mm turbo this one could probably out flow would be the rcd 68mm, and that's only because it uses the stock powermax turbine wheel. Other than that I don't see this outflowing any of the others out there.
ODAWG714 likes this.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 5 Old 05-29-2014, 06:10 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
A cast wheel 66 out flowing a billet 68? I have to call bs and misleading product description, they must have compared against the most terribly built 68 on the planet. Jmo. The turbo market is over saturated IMO...
ODAWG714 and JGman141 like this.
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #4 of 5 Old 05-29-2014, 06:38 PM Thread Starter
borsky4's Avatar
Ya i agree it sounds like bs. Interesting none the less,
borsky4 is offline
post #5 of 5 Old 05-30-2014, 11:06 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 134 Post(s)
Does it matter they are using a GT40 turbine. It just might.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
