New Fel Pro Head Gaskets - Ford Powerstroke Diesel Forum
 10Likes
post #1 of 23 Old 05-29-2014, 04:02 AM Thread Starter
Has anyone heard about the new Fel Pro head gaskets? I saw them at a show and they are claiming they are superior to the oem. Fel Pro has made quality gaskets over the years it will be interesting to see how this turns out.
Fgroce is offline
post #2 of 23 Old 05-29-2014, 08:43 AM
Term3's Avatar
Black Onyx also claimed to be better then OEM when they came out. Don't believe everything you read but if you want to test those gaskets on a high HP studded 6.0 and post your findings I'll subscribe to that thread.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 23 Old 05-29-2014, 09:52 AM
borsky4's Avatar
Are they mls gaskets? Got any pics?
2006 CC SB, SRW, Barder stg #2, Ported manifold, Warren 190 30's, banks CAC, SCT Tuned by/IDP, IDP ficm tunes, nadp trans, fluidampr, FASS LP, Driven RR, edge insight, HPODS, BD ex manifolds, HD y pipe all ceramic coated & wrapped, UCF O-ringed heads with arp's, Colt stg 1 cam with RCD springs and tubes,
6" lift/trac bars, 37's 4:30 gears, Future mods: non VGT T4 64mm BASB
borsky4 is offline
post #4 of 23 Old 05-29-2014, 10:09 AM
Heavy_GD's Avatar
Quoted: 1440 Post(s)
Feedback Score: 3 reviews
sinner6.0L and tinglef like this.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #5 of 23 Old 05-29-2014, 07:44 PM
We have installed some at our shop they look real similar to OEM. They have black stripes where the blue stripes are on OEMs. They are MLS gaskets. But the truck was stock so the verdict is still out.
turdblow is offline
post #6 of 23 Old 05-29-2014, 08:48 PM
borsky4's Avatar
Sounds like the black diamond gaskets...
borsky4 is offline
post #7 of 23 Old 07-15-2014, 06:27 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 56 Post(s)
Feedback Score: 7 reviews
Rcd has a set of mls now too. Fel pro is top notch in the gasser world. Would be nice to have an alternative to ford.
ZMANN likes this.
God bless America, the Constitution and the Second Amendment.
powerstrokeshellback is offline
post #8 of 23 Old 07-15-2014, 06:38 PM
Is there a problem with the OEM gaskets??? No there isnt. Why are people always wanting to try a new gasket when there is a gasket out already that is proven to work well. Is saving $50 really worth the chance?
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #9 of 23 Old 07-15-2014, 06:53 PM
Quoted: 56 Post(s)
Uhh... Yeah. If rcd and/or fel pro measure up. Why would you not want to save money.
post #10 of 23 Old 07-15-2014, 07:01 PM
smoke=cool=little kid
Shark diver must clearly have a stock truck... anything above 600hp is not so bulletproof, remember. No matter how much makeup applied to the pig, its still a pig, for instance, 4 bolts per cylinder. The heads don't have enough clamping force to be sealing baskets, even OEM. My money is at hyper ax o ringed gaskets and ARP 625s
ZIKA and bgraiders323 like this.
2004 F250 CCSB 44
Typical mods and performance parts
SCjake is offline
