Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 12-21-2008, 03:50 PM
map sensor
where is the map sensor djs fuel + says you half to tap into?
Old 12-21-2008, 05:15 PM
NOW: KNOCKING NOISE
It's on the passenger side. It is mounted to the heater/A/C box. There are 3 10mm nuts the hold a triangle mounting bracket to the box and the MAP sensor is on that bracket.
Old 12-21-2008, 05:23 PM
thanks man do you happen to have a pic?
Old 12-21-2008, 05:24 PM
NOW: KNOCKING NOISE
I'll get you one.
Old 12-21-2008, 05:26 PM
left side, what the red hose plugs into. Its the plastic plug infront
Old 12-21-2008, 05:27 PM
Crap
I just realized im in the 6.0 area again, disregard.
Old 12-21-2008, 05:48 PM
NOW: KNOCKING NOISE
Here you go bud.
Old 12-21-2008, 06:00 PM
which one is the tube?
Old 12-21-2008, 06:02 PM
NOW: KNOCKING NOISE
Just take the 3 nuts off and pull that mounting bracket up to see it. I believe it is the one with the wire loom on it.
Old 12-21-2008, 06:07 PM
thanks for your help and pics bud!!
i like the djs kit but i wish it would have came with better instructions or pics even!
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
