Xcal 2 ????????
If you have an xcal2 that came off a mustang, how do you erase his tunes and add yours?
Do you have the liveload software downloaded from SCT's website?
yes i do....................
is it a custom tune programmer or does it have preloaded tunes on it???
the custom tune one
do you have tunes ready to load??
yea i got the frmo eric yesterda
i assume you have the liveload program already installed on teh computer. So you will need to plug a printer cable into the bottom of your unit, click your liveload icon. then click erase files... dont click the one that says erase device. that will reomve any of the mustangs files. once you do that let me know.
ohh ok, but i am at work ill do it later thanks
oh ok, well once you erase the files, you click unlock device. that will make it so it can be used on your truck. once it is unlocked, you click on file 1, then click browse, find your file that you want to load to that position, and click add file. then click file 2 and do the same, for up to 3 files... it should then be ready to go. if you have any more issues you can check here or talk to Eric about it.
