ARP Bolts??? - Ford Powerstroke Diesel Forum
Old 12-14-2008, 09:03 PM
ARP Bolts???
I was talkin to a guy at work about getting the truck studded, and he told me to look into ARP Bolts as well as the studs...from what he told me is the heads mount on the bolts...meaning the bolts come from the bottom up and you place a nut on the top (i'm guessing)...supposedly even better than studs...any input?
Old 12-14-2008, 09:12 PM
The studs screw into the block then you set the heads on the block and then you use the nuts to secure the heads to the block. The way the bolt work is you wet the heads on the block and then bolt it to the block. Studs have no head for a socket. Bolts have a head for a socket.
Old 12-14-2008, 09:16 PM
This is how the studs work
The block
Studs in the block
Heads on the block
Heads bolted down with 12 point nuts
