Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 12-07-2006, 07:45 AM
2DreamX 2DreamX is offline
Send a message via AIM to 2DreamX
lookin for some new toys for christmas
what can yall tell me about the water/meth system? it sounds like a good system but im also was thinkin about propane injection. what do you all think?
could they be used together later on down the road?
thanks!
Old 12-07-2006, 07:53 AM
Logan Logan is offline
The Fat Mod
Alot of people really like it. Rodslinger(Alan) has a stage three on his, and I think he has been real pleased with it, but I will let him speak to that. I have not heard any problems running both. I know if you are planning on doing any sled pulls, alot of rules will let you run straight water and they will not let you run or N20. basicly, if you are running 100% water, it cools your egts several hundred degrees. If you are running upto a 50/50 mix with H2O and Meth, I belive you can get a pretty decent HP boost as well. But, all of this is from what I have read and heard, so no real first hand knowledge, but I hope this helps any way.
Old 12-07-2006, 08:37 AM
farmboysdiesel farmboysdiesel is offline
I would run water before I would run propane. The cylinder pressures made by propane would be higher than that of water/meth injection.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
