Air Intake ? - Ford Powerstroke Diesel Forum
Old 11-19-2008, 08:41 AM
Exclamation Air Intake ?
i was wonderin what would be the best intake for the money, and i was also wonderin if the intake changes the way the truck sounds, one of my friends told me that his changed
Old 11-19-2008, 08:49 AM
well first of all you dont have to change your intake.. your stocker will flow more than enough air to support 400HP
if you really want to change it S&B is one of the best bang for your bucks out their: S&B 6.0L Intake
it will change the sound a lil bit... basically you will be able to hear it sucking in the air...
Old 11-19-2008, 09:00 AM
say no to rolling coal
I know an intake isn't necessary, but I am a big fan of them. Yes you can hear the airflow being sucked in, it makes the turbo whistle just a bit louder in the cab. Mine breathes so hard it will draw the filter minder in just by the force of air being sucked in...
Old 11-19-2008, 09:23 AM
so the only change in sound is the air bein sucked in, it really dont change like the exhaust sound ?
Old 11-19-2008, 09:25 AM
only an exhaust would change the exhaust sound... you basically can hear your turbo spool up a lil more than with the stock setup.....
what all do you have done to your truck?
Old 11-19-2008, 09:34 AM
its a 03 lariat cc 6.0 I guess the worst year ever it has 134,000 mi, currently i just have a 4in turbo back exhaust from fbd, and was thinkin about orderin a intake and the edge insight from STEALTH AUTO. and maybe a chip, but ive read about all the egr and head problems, the egr and studs seem like it would be expensive to do ?
Old 11-19-2008, 09:43 AM
the studs you can get for like 500 bucks but its the labor that kills you... i think its in the 1500+ for labor on headstuds... you can do a EGR delete for fairly cheap.. but you need to know how to weld...
if your gonna go with an intake i highly suggest the S&B intake.. best bang for your bucks on intakes....
as far as gauges go i would just get a set of regular pillar gauges... the insight is nice but i have always personally liked analog gauges better... i have had both and both at the same time and it was harder for me to read the digital readouts while i was driving... i could make sense of the analog gauges faster...
plus the insight reads off a inaccurate trans temp sensor from the factory.. you want a real gauge reading...
-Raul
Old 11-19-2008, 09:47 AM
I'm a big fan of analog gauges too. My quad commander is up for sale because I did not like it much. Switched to a set of real gauges and couldn't be happier.
Old 11-19-2008, 05:14 PM
Try cutting the snorkle off, it will change the exhaust tone.
Old 11-19-2008, 05:19 PM
right but at 70 bucks a pop for a filter, 4 filters and you have a new intake with a reusable filter!
