Exhaust Question - Ford Powerstroke Diesel Forum
Old 11-19-2008, 07:24 AM
Send a message via AIM to FastFocus
Exhaust Question
Hey all, ok i know i've been asking a ton of questions, but so far everyone has been a great help. this is my last one for a bit.
The stock exhaust is 3.5" i'm looking for an exhaust for better MPG. I was looking at the 5" exhaust(for sound and mpg's) but i've been told i dont need it til 500hp, which i'm not going after for a while(at least till warranty is up). So then i started looking at 4" exhaust. I know i need the stock cat to keep my warranty. so a 4" turbo back MBRP with keeping the stock cat is $380.
my question is this. Instead of paying close to $400 for exhaust. Can i gut the cat to keep the Cat appearance, and replace the muffler with a straight through muffler since the stock pipe is only .5" less than the 4" aftermarket and get almost the same MPG's?
i don't see how .5" is going to be that big of a deal, but i could be wrong. thanks,
Old 11-19-2008, 07:29 AM
just take off the muff..... you can gut the cat...
you will not really see any diff in MPG though.. even if you went with a 4" kit...
their are a lot of things that determine MPG.. thinks like:
Tire pressure
Clean filters
your right foot
then tuning, and flow
a larger 4" exhaust is only meant for a lil better flow and to get those EGT's down lower once your tuned....
Old 11-19-2008, 07:52 AM
well i'd like to put a straight through muffler on it, i don't really wanna hear the turbo wine THAT loud. what do you recommend for a straight through muffler.
also, i've heard that an intake, box and chip will improve mpg's and really open these trucks up. is that not true?
Old 11-19-2008, 07:54 AM
im not sure of anyone that makes a straight through muff for a stock exhaust.. their are plenty that make it for a 4" though...
your stock intake will flow more than enough air to support over 400hp.. so you dont need an intake.....
if you really want better MPG then you need to install a tuner... and gauges...
i recommend a custom tuned SCT.. it is the best for the 6.0L
