EGR Block Off Kit - Ford Powerstroke Diesel Forum
Old 11-17-2008, 04:48 PM
EGR Block Off Kit
Hey all I'm getting ready to do my studs and I figured while I'm at it I'd block off m EGR. Found this one on eBay, was wondering what you all think?
Thanks...
eBay Motors: 03-07 6.0 POWERSTROKE FORD EGR COOLER BLOCK OFF KIT (item 190267173848 end time Nov-25-08 14:22:26 PST)
Old 11-17-2008, 04:53 PM
Illiana Chapter Director
Thanks...
If you are going to just block it off try this. It is the 3rd one down. 6.0L EGR Components If you want to eliminate the whole EGR system, check this out. Product Detail Hope this helps some.
Old 11-17-2008, 05:02 PM
Is this the one you used? If so how do you like it, any codes? Also which one is better to do?
Old 11-17-2008, 05:04 PM
I just used the plate from Elite because I don't have the SCT to turn the EGR system off. No check engine light with the block off plate, but when I get the SCT, I'm doing the complete EGR removal from firstcoastdiesel performance.
Old 11-17-2008, 05:14 PM
Is this a weld on plate??? Also if I put this on do I still have to worry about the cooler failing?
Old 11-17-2008, 05:16 PM
It doesn't weld on. Just sits in a recess where the cooler bolts. The cooler can still fail but not as likely. That's why I'm going to install the complete kit when I get the SCT.
Old 11-17-2008, 05:19 PM
I know this is a stupid question, but why would blocking off the egr be worth while?
Old 11-17-2008, 05:20 PM
The EGR is what sends the hot gases through the EGR cooler which is why the cooler blows.
Old 11-17-2008, 05:24 PM
So by doing this I take it no more hot gases right? So does this mean the egr valve doesn't have to be cleaned anymore?
