Aftermarket Intercoolers in the 6.0 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-15-2008, 07:11 AM Thread Starter
shfletchak's Avatar
Haven't seen too much about intercoolers for 6.0's on here...
Is it worth the 1000 bucks to get an aftermarket intercooler?
Does it keep temps down that much more than stock to be worth it?
2005 F250 CC FX4 6.0L SCT Livewire, 4" Turbo back MBRP Exhaust, EGR/DPF Deleted, Zoodad, Airaid Intake, 33" BFG ATs, Leer Browning Edition Topper, High Idle, High beam-fog light Mod, Airlift Springs, homemade lightbar/4 Moose lights
2004 F150 SCrew 4X4 4.6L
K&N Intake, Flowmaster Dual Exhaust, 33" BFG ATs, leveled, Smittybilt Brush gaurd/tube steps, 4 Moose lights, Air helper springs, Leer Browning Edition Topper
2011 26Z2 Arctic Fox TT
shfletchak is offline
post #2 of 12 Old 11-15-2008, 07:12 AM
Abrannan19's Avatar
Feedback Score: 5 reviews
expect nothing over 50-100 degree's lower..nothing more..
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #3 of 12 Old 11-15-2008, 07:13 AM
Ole White
bigwhite7.3stroker's Avatar
Yes it will lower EGT's 100-125 degree's and is the best way to go especially if you tow alot
Looking for 05-07 front end with Harley Lights
bigwhite7.3stroker is offline
post #4 of 12 Old 11-15-2008, 08:06 AM
pitamarillo84's Avatar
plus you wont have to worry about blowing the end tanks off of the ****ty stock one when towing(happened to me) i got the banks techni cooler couldn't be happier with it its worth it for that fact alone not to mention the egt drop.
pitamarillo84 is offline
post #5 of 12 Old 11-16-2008, 01:10 AM Thread Starter
shfletchak's Avatar
Yes I do tow a lot, mainly in the mountains in Idaho. Head gasket went a couple months ago is mainly why I was looking at them, hoping to keep it from happening again.
post #6 of 12 Old 11-16-2008, 02:29 PM
Totally off the subject, but I saw that you spend alot of time in the mountains in idaho. i'm form Boston, but spent the summer of 06 in McCall doing some High Voltage work on Tamarack. beautiful country!
ok..... on the subject. how much does i cost to put in an intercooler? or is it an easy enough project to tackle on my own......
I'm an electrician, not a mechanic buy any means.........
xbostonirishx is offline
post #7 of 12 Old 11-16-2008, 02:35 PM
the Banks techni cooler kit for the 6.0 is around 1000 bucks and easy to install just follow the instuctions that are supplied with it a couple of hours and your done
post #8 of 12 Old 11-16-2008, 02:35 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 108 Post(s)
Feedback Score: 3 reviews
With my Spearco I cruise unloaded on the HWY at 65MPH running 600* EGTs. Biggest factor is the amount of boost while driving.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #9 of 12 Old 11-18-2008, 08:17 PM
youngstroker's Avatar
how much did it affect your boost
03 super cab, 6.0l, short bed, 4x4, muffler and cat delete, 285/75R16 dunlop rover m/t, SCT x3 tuned by kem performance, auto meter gauges, cfm intake manifold.
youngstroker is offline
post #10 of 12 Old 11-19-2008, 06:02 AM
it does seem to show a small amount of psi loss but also remember that there is a significant increase in surface area inside the cooler and pipes so even though u see a very small if any drop of psi it still getting as much or more air then u where b4 but it's at a lower temp and therefore more dense I am still able to hit 37psi with the HP tunes it is well worth the $$$$ just my 2cents
