Head Studs
So I'm getting a custom tune from Eric and I'm not sure if I have head studs or not...i'm going to check tomorrow but just in case I don't have them, I'm just wondering how hard it really is to install head studs? Do you HAVE to pull the cab? How long does it usually take? How much does it cost???
Thanks in advance -Ben |
for the 6.0 from what I understand is that you have to pull the cab, or motor. the are usealy like 400-500 bucks for the kit.
You can do it with out taking the cab off!!! just have to remove the intake, evaporator case, and anything connected to the heads. you have to have a heavy duty crane to do it though. it is a pain in the *** and very time consuming. also very expensive!! you can pull the cab if you have the recourses to do so!!
i know a guy that lifted his cab with 2 genie crank lift that he rented and then set the cab on the top of the bed sitting on some wood to support it.
