WW2 learning curve on stock turbo? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 03-01-2014, 09:57 AM Thread Starter
ok I had a friend that installed a WW2 on a stock 05-07 turbo. After that he had max boost issue being that they where low. No leaks on the exhaust side on intake side. But after a period of time his boost came back. Now fast forward. I rebuild my stock turbo and installed a WW2 in it. Since it got into the 30s today I went out and swapped the powermax out for the stocker WW2 combo. I see the same thing on my 04 turbo as his 05-07. It's not a exhaust leak, and I know it's not a intake side leak either. Boost vs MAF look about right and bottom end and crusing is good. I even swapped out the VGT solenoids and same thing. I see about 22-23 until it the converter locks then I see 25-26 for a second or two. If I went back to the Powermax or the stock compressor wheel I would be fine again. Since this is the second turbo that has done this I'm pretty sure it has to do with the wheel. I just wanted to throw some feelers out there for those that have used these before because it's about to become a desk paper weight.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #2 of 14 Old 03-01-2014, 10:52 AM
westcoast6.0's Avatar
When I had my WW2 on my 05 I saw lower boost pressure my it had a bit more power. Got a little better mpg's spooled a little quicker seemed more efficient I guess. I think about 26 or so was about the most boost I saw with stock gage
Erick
2005 White CCSB 4X4
MBRP 4" straight pipe
RiffRaff Boots
Updated metal CAC tube
S&B CAI
Zoodad
ARP Head Studs
BPD EGR Cooler
OEM Oil Cooler
BPD Water Pump
Barder Stage 2 turbo
6.4 Banjo Bolts
Blue Spring
Zerex ELC-1 Coolant
SCT X3
Tunes: SPD, SRL+, XTREME STREET
Rudy's Diesel Up-Pipes
westcoast6.0 is offline
post #3 of 14 Old 03-01-2014, 10:59 AM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
That's about what I'm seeing with the same turbo Erick had on his truck. About 25-26 max.
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #4 of 14 Old 03-01-2014, 11:07 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Yeah, I'm seeing the same numbers.
I'm not sure the WW2 is supposed to increase boost psi, but rather increase the density of the air and do it in a quicker way, decreasing spool-up time...
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #5 of 14 Old 03-01-2014, 11:46 AM Thread Starter
Ok, so I'm not the only one. Well I need to run some more test and maybe even go back to the cast wheel or a KTS wheel. I'm not concerned about boost because so many things affect it and a crappy running truck can have high boost. What I am concerned about is MAF numbers. on a side note a stock turbo with a WW2 so far is flowing around 400-420 g/s MAF and the powermax with SP billet flowed 460 g/s + MAF. Also I'm not sure spool up is much quicker than the powermax billet combo. Anyways off for more testing.
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #6 of 14 Old 03-01-2014, 02:40 PM Thread Starter
I rolled back to stock tonight and my emissions still function. I'll be getting some MAF readings to check again cast wheel MAF readings.
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #7 of 14 Old 03-01-2014, 02:55 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 141 Post(s)
Feedback Score: 3 reviews
Ever wonder what the PCM does?? Using all the sensors it makes adjustments. Watch VGT% and note the differences.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #8 of 14 Old 03-01-2014, 03:33 PM Thread Starter
I'm not sure how to take this.
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #9 of 14 Old 03-01-2014, 03:41 PM
N.S.D.Q.
Quoted: 141 Post(s)
Just another suggestion for answering your question. Everyone forgets these trucks are controlled by a computer. Consider the changes you made. Why is it you only look at boost PSI?? There are several sensors the PCM uses and will makes changes. Just cause truck X made 30 PSI boost, doesn't mean truck Y will do the exact same thing.
post #10 of 14 Old 03-01-2014, 04:02 PM Thread Starter
Wow talk about arrogance. Well considering I've used all the strategy's cyh0-7 on my truck, I've used three difference wheels in the powermax, and now two in the stocker. I've data logged difference in air intakes, intercoolers and other part changes I'm pretty sure I know how and what the ECM does or doesn't do. I'm also versed depending on which strategy I run how long the learning curve is on the ECM or TCM. I also know boost is a piss poor measure of air flow given everything that affects boost. heck I've even programmed the Accell DFI system on my old Vortech XX mondo supercharged 93 mustang back in the day. This thread was basically a feeler to see if others where seeing the same thing that's it nothing more. But hey thanks for the input.
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
