truck acting up - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 27 Old 02-27-2014, 01:25 PM Thread Starter
smoke=cool=little kid
truck acting up
I was driving home, my instrument cluster stopped working, abs light on, no check engine light, truck still ran... pulled onto my street, turned it off, tried starting but wouldn't start, tried again started but gauges still didn't work, my windows wouldn't roll up or down. But still drive fine. I opened my hood an my fuel pressure was at 43psi, no fuses were blown. So I turned it off. I would turn the let to on position an I would here the injectors buzz an gauges would work for a second then all of the sudden they stopped working after a second an injectors stopped buzzing but fuel pump was still on. So what the hell? I swapped my 305 trailer fuse with my 302 pcm fuse an the gauges worked an everything else went back to normal but my fuel pressure is still at 42psi... and ideas or anyone every experience such a problem. I haven't found another like it.
2004 F250 CCSB 44
Typical mods and performance parts
SCjake is offline
post #2 of 27 Old 02-27-2014, 02:27 PM Thread Starter
Also I just swapped the other fuses from 305 to 302 an its fine... a fuel pump failing couldn't cause this could it?
2004 F250 CCSB 44
SCjake is offline
post #3 of 27 Old 02-27-2014, 02:39 PM
6 L chevy eater's Avatar
Wish I had some input for u, but I have no clue. Sorry
ODAWG714 likes this.
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #4 of 27 Old 02-27-2014, 02:45 PM Thread Starter
Its intermittent... sometimes the gauge cluster comes on an the truck runs, then I turn the key on again an no gauges, turns over fires off for a second then dies
2004 F250 CCSB 44
SCjake is offline
post #5 of 27 Old 02-27-2014, 02:46 PM Thread Starter
Its something electrical, I just can't figure out what.
Edit: is there a battery isolator on our trucks or would it be in the alternator? Gona test batteries an alternator
2004 F250 CCSB 44
SCjake is offline
post #6 of 27 Old 02-27-2014, 03:07 PM
colonel angus's Avatar
Quoted: 2 Post(s)
I would start with all the ground points since that is a common point for a lot of connections. Someone else will have to tell you where they all hide.
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
The Following User Says Thank You to colonel angus For This Useful Post:
SCjake (02-27-2014)
post #7 of 27 Old 02-27-2014, 03:47 PM
snafu!'s Avatar
Possibly the gem module or a connection to the gem module, since it's affecting the windows also.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
The Following User Says Thank You to snafu! For This Useful Post:
SCjake (02-27-2014)
post #8 of 27 Old 02-27-2014, 04:11 PM Thread Starter
Grounds are good. What's the gem?
2004 F250 CCSB 44
SCjake is offline
post #9 of 27 Old 02-27-2014, 04:19 PM
COONASS
WHAT HAPPENED's Avatar
2005 CCLB FX4
ARP, EGR Delete, 5 inch TB, SCT Livewire, Sinister Coolant filtration, ECL-1, PHP TUNES
Federal Ownership Respectfully Declined
WHAT HAPPENED is offline
post #10 of 27 Old 02-27-2014, 04:31 PM
Heavy_GD's Avatar
Quoted: 1733 Post(s)
Feedback Score: 3 reviews
GEMs stopped in o3
Ford GEM Modules Auto Parts Cheaper Blog
What does a GEM Do?
A GEM controls all the basic functions of the interior electrical of the truck
Each configuration of a GEM on a vehicle can do many things, the most common things a GEM does is listed below, this is not an all-inclusive list, but includes the, most common options only:
Controls 4X4 on 4 wheel drive modes that have ESOF (knob on dash to control 4 wheel drive).
Supplies power to the radio.
controls power windows and locks
some modules include receivers for key less entry.
Controls Windshield wipers.
Controls Dome Light.
Those are just the basics, they do other things on different vehicles, there are over 180 combinations of options.
Where is it located?
In 1997-2001 Models it is bolted to the back of the interior fuse box. On 2002-2003 models it is on the back of the fuse box or behind the dash on the passenger side.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
