MITUSA Fuel System - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-27-2014, 09:01 AM Thread Starter
MITUSA Fuel System
Hey guys,
Just picked up the truck in my sig a week ago after driving a duramax for 5 years so I have been in the diesel world for a little while but always wanted a ford. After having the Dmax stolen and broken into multiple times, the front end falling apart, and beating the **** out of it on ranch roads I decided to retire it and go for a Ford. Im in the dallas area so when my truck popped up on Craigslist I couldn't resist. So far I love the truck and hope to drive it for years to come. However like most I have the itch to start modding and would love some advice from those with experience working on these trucks. First and foremost I want to upgrade the fuel system to prevent an undo stress when I start playing with bigger tunes. On my duramax I ran the MITUSA belt driven lift pump and loved it as it held rail pressure on any tune I ran and made no noise. I kept the MITUSA intending to sell it but now that I am back in a diesel I wanted to see if anyone here has modified a MITUSA fuel system to work on a ford as they are not offered for Fords. Or if anyone has any insight as to why this system would not work on my truck I would love to hear it. Heres the link to the website for the MITUSA.
Learn more about our high performance diesel products!
I plan to email Opie as well and ask his opinion but thought I would throw this out there in case I find a way to make this work and anyone else wants to follow suit.
On another note, I plan to keep this truck balanced between reliability and performance but I would like to hear some suggestions from guys on DD race tunes for the 6.0 as the SCT canned tunes are not anything special. I know I can search the board for this and intend to do my research but it never hurts to ask.
Thanks
James
2005 King Ranch F250 6.0
  • "Bulletproofed"
  • SCT Tuned (PHP tunes on the way)
  • 4" Exhaust
  • Airraid Intake
  • Viper Security/Remote Start
  • Blue Spring Upgrade
  • STC Fitting/Dummy Plugs
JPreston is offline
post #2 of 6 Old 02-27-2014, 09:20 AM
Heavy_GD's Avatar
Quoted: 1496 Post(s)
Feedback Score: 3 reviews
has it had the 6.0 work over? (link in my sig)
GD
Heavy_GD is offline
post #3 of 6 Old 02-27-2014, 09:37 AM Thread Starter
Haven't had the chance to install gauges but that's on my list of things to do. But the EGR is deleted, studs are in, gaskets replaced, and I believe the oil system was updated. I need to get a complete list of the work done because I bought the truck with these mods done already. Do I need to do the coolant filtration system even though the EGR is deleted?
On a side note, my truck gets a little lope going after cold starting. Is this something to be concerned about? It's fine once warmed up but when i go to start it up in the morning it kinda chugs until it gets warm
James
  • "Bulletproofed"
  • 4" Exhaust
  • Airraid Intake
JPreston is offline
post #4 of 6 Old 02-27-2014, 09:45 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
The EGR delete will keep the EGR cooler being ruptured and resulting head gasket issues out of the picture. However you can still have the oil cooler clog up as a result of junk in the cooling system so a coolant filter isn't a bad idea.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 6 Old 02-27-2014, 09:49 AM
PGreenSVT's Avatar
I don't know jack about the MITUSA fuel system but the Dmax and the 6.0 fuel systems and injection system are entirely different animals. There are lots of threads on fuel system upgrades from adding a 6.4 pump to the stock system to complete replacement systems built around an Areomotive or Fuelab pump.
RIP Mitch
the Org crew
post #6 of 6 Old 02-27-2014, 11:26 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
For the fuel system, the stock pump works very well until you start to push more tuned power. The MITUSA pump could work as a lift pump, to feed the stock pump, but after all the routing and plumbing, it probably isn't worth the effort. As you may already know, the 6.0 is not a common rail and the high pressure fuel is created by the oil system and the injector itself. It needs 55 psi of fuel at the head to work properly.
The cold start lope is most often a result of stiction in the spool valves, usually caused by long oil changes and sludge forming varnish creating drag or sticky injector spools. Using a 5w40 synthetic oil will help, but you may need to try RevX or Archoil to see if that helps. If it doesn't (which is usually the case) you can mechanically clean them by following the process in my sig. Welcome.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
