whats a good alternator upgrade? - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 35 Old 02-26-2014, 05:01 PM Thread Starter
B_router's Avatar
just got off the phone with Ed at FICMrepair.com and it sounds like I need a new alternator anybody have any suggestions on a unit that will be a upgrade from the stock POS and give me enough juice that I wont need to call Ed again? In the last 30 days I've run this truck through the laundry list of upgrades every 6.0 needs so I'm a little tight on cash but don't want to leave it alone and don't want to replace it with stock either.
B_router is offline
post #2 of 35 Old 02-26-2014, 05:08 PM
Quoted: 58 Post(s)
DC Power 185 or 190 amp.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 35 Old 02-26-2014, 05:12 PM Thread Starter
B_router's Avatar
will I be good with stock wiring harness or should I wire to the battery?
B_router is offline
post #4 of 35 Old 02-26-2014, 05:15 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I went with one from AUTOZONE. Its not as cool as the DC Power but seems to be doing a bang up job. Has a lifetime warranty. And so far handles all the power output that I have asked from it.
Something else you might think about is called the Big 3 upgrade.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 35 Old 02-26-2014, 05:19 PM Thread Starter
B_router's Avatar
Big 3 huh.....wtf is that? sounds like the starting line up for the Miami heat!! Ed said just to pay attention to idling amps and make sure they are around 100 and I should be good.
B_router is offline
post #6 of 35 Old 02-26-2014, 05:26 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
check this out-lookin 4 "Big 3 upgrade" pics-
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 35 Old 02-26-2014, 05:32 PM Thread Starter
B_router's Avatar
makes sense, this probably is a good thing to do when you jump to a higher amp output. With this awful winter we've had in Indiana im thinking about a snow plow next year, would i need to go even higher amps?
B_router is offline
post #8 of 35 Old 02-26-2014, 05:44 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
well if your going with a plow you might be better off with a DC power set up. But Im gonna bet that 99.999999999% of all the 6.0 snow plow trucks in the world are just running a stock high output alt.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 35 Old 02-26-2014, 05:48 PM Thread Starter
B_router's Avatar
I hate to mention but would a cheaper 140 amp like this DL3668-8-11 be an improvement from stock and get me by. Or should I bit the bullet and go big.
B_router is offline
post #10 of 35 Old 02-26-2014, 05:53 PM
dc power 185 amp and big 3 mod and never look back... i procrastinated for over a year and finally bit the bullet(my stock one failed too) and got a dc and upgraded wiring. your truck will love you for it. i used 1awg wire.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
