XCal 2 Problem - Ford Powerstroke Diesel Forum
Old 11-07-2008, 07:56 AM
XCal 2 Problem
I'm having a problem with my XCal 2. When I plug it it to my OBD2 port the programmer comes on, then I go to select a tune and it tells me to "Turn truck on but don't start." I then turn the truck on and the tuner does nothing. Its not recognizing when I turn the truck on. Anyone have this problem? I need to return my turn to stock and take it to the dealer, but I can't get the tuner to work right. Any help would be appreciated. Thanks
Rob
Old 11-07-2008, 12:24 PM
The Lady Mod
Send a message via Yahoo to Granny
For some reason it is not recognizing your truck. I would give Eric a call. I am sure he can help you.
Old 11-20-2008, 10:32 AM
Okay so Eric had me contact SCT tech support. SCT told me to check all my relays and fuses, and if nothings wrong there then check the battery voltage. Well everything looks good, and I haven't had any battery problems so I'm still stuck with a tuner that doesn't recognize "key On!"
Anyone have any other suggestions?
Old 11-20-2008, 10:35 AM
Almostdunfukinwidit
Check your lighter fuse. Other than that not sure
