Turbo Rebuild - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-26-2014, 04:31 PM Thread Starter
Protronics00's Avatar
Turbo Rebuild
Just rebuilt my 03 turbo and all works great until I torque my wheel on. I follow riff raffs directions and torque it to 10 ft lbs but the shaft gets very tight and won't turn. What is the problem.
Protronics00 is offline
post #2 of 11 Old 02-26-2014, 05:08 PM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1667 Post(s)
Feedback Score: 4 reviews
do you not have the rear seal fully seated?
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #3 of 11 Old 02-26-2014, 05:12 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
You don't have the shaft all the way home in the turbine side, sometimes the ring seal catches, or you don't have the compressor section on the CHRA correctly. If it is all level or very slightly protruding into the compressor section at the backing plate, you will have no binding.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 11 Old 02-26-2014, 05:12 PM Thread Starter
It does pull out a lot easier than it did when I rebuilt it. I didn't hit it with a hammer but it seems seated. I will check it again to see. Thanks
post #5 of 11 Old 02-26-2014, 05:32 PM
You shouldn't need to hit it hard, just a light tap.....it will "snap" and "click" into place once the seal is sitting in it's seat
post #6 of 11 Old 02-26-2014, 05:54 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
If I remember correctly you have a clamp style 03 turbo. This may actually take a different bearing kit than the later turbos. Do all your old components look the same as your new ones?
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
The Following User Says Thank You to sinner6.0L For This Useful Post:
Protronics00 (02-26-2014)
post #7 of 11 Old 02-26-2014, 07:50 PM Thread Starter
I got it. It just wasn't seating properly. First rebuild and it was definitely a learning experience. A huge thank you to Peixinho for getting me a new back plate and housing as well as walking me through some difficult steps. You are the kind of person this forum needs. Also thank you Sinner6.0L for your help as well. I hope I can return the favor one day.
post #8 of 11 Old 02-27-2014, 05:32 AM
HP MACHINE's Avatar
Quoted: 104 Post(s)
Question here , what is "clamp style " referring to ?
HP MACHINE is offline
post #9 of 11 Old 02-27-2014, 05:47 AM Thread Starter
Turbo Rebuild
The front housing has the holes for bolts just like normal. The housing is held on by straps similar to the picture below. The backing plate does not have threads in it to accept any bolts. Bolts go through the front and into these which gives you the clamp style. Turbo Rebuild-imageuploadedbyag-free1393508840.640847.jpg
Hope this helps.
post #10 of 11 Old 02-27-2014, 05:53 AM Thread Starter
Here is a picture of the whole setup.
