Pmax billet wheel to use - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 14 Old 02-26-2014, 12:44 PM Thread Starter
ok, looking for some opinions. Getting ready to built a turbo and looking for opinions on the WW2 for the Pmax against the KTS single plane pmax wheel. I have a Batmo sitting on the self that I used before but after using the KTS SP wheel I want to stick with a SP wheel. Just not sure which one. I'll be leaving my current SP wheel in my current Pmax and buying a new Pmax to build off of which is why I need the wheel.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #2 of 14 Old 02-26-2014, 02:26 PM
peixinho's Avatar
Quoted: 174 Post(s)
Just curious why the switch? You already have a pmax with a single plane wheel but want to buy a new pmax and put a new single plane wheel in it?
The differences between most of the wheels is going to be very small. The biggest difference will be between single plane and dual plane wheels. If you put any of the single plane wheels up against each other... I would venture to say that you would see very little to no difference on the butt dyno or the real dyno. Most of all the turbo shops already by the wheels from the same source... lol... most of them are even the exact same wheel but just call it different things.
JGman141 likes this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #3 of 14 Old 02-26-2014, 05:37 PM
work&play's Avatar
Quoted: 2 Post(s)
I got my SP wheel for my Powermax from MTW and like it a lot.
2007 6.0 PSD,F350 4X4 Lariat,CC, DRW,9' Knapheide body, stainless steel lader rack, SCT with custom tunes, ARP's, EGR delete, ITP RR, Airdog II 130/75, Garrett Powermax, Banks turbo back, Firestone air bags, Autometer gauges
work&play is offline
post #4 of 14 Old 02-26-2014, 05:53 PM
XL trash...
Merc82's Avatar
Quoted: 268 Post(s)
Same here. Really woke the turbo up.
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #5 of 14 Old 02-26-2014, 06:20 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
I have a new Pmax and new sp billet wheel if you are interested.
PM me if so
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #6 of 14 Old 02-26-2014, 06:27 PM Thread Starter
I'm going to be installing my 04 turbine and 04 turbine housing and vanes at the same time. The Pmax whistle is starting to get to me and I really don't want to go back to the 04 turbo even though I still may since I just rebuilt it.
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #7 of 14 Old 02-26-2014, 06:55 PM
snafu!'s Avatar
IMO I would go with a WW2 if your going to a 13 blade turbine, I think you'll run out up top with a 11 blade single plane.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #8 of 14 Old 02-26-2014, 07:00 PM Thread Starter
The WW2 for the powermax is a 11 blade single plane like the KTS 11 blade wheel but taller and maybe a few other minor differences.
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #9 of 14 Old 02-26-2014, 07:09 PM
snafu!'s Avatar
Oh my bad, thought it was a 6x6 DP like for the stock turbos. I know the 13 blade turbine and a 64.7 SP is not a good combo and runs out of air on top. The batmo actually made more HP than the 11 blade SP on the 64.7.
Cameron
Warren 285/100
ODAWG ported intake
Built Trans
Water/Meth
snafu! is offline
post #10 of 14 Old 02-26-2014, 07:14 PM
peixinho's Avatar
Quoted: 174 Post(s)
So you are trying to make a "stage 1" turbo...
13 bladed turbine with a pmax billet wheel?
I might actually be able to help you with that... and maybe throw in a .72ar race cover.
PM sent
KC Turbos
peixinho is offline
