What programmer/tune do you recommend? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-26-2014, 10:15 AM Thread Starter
mad103's Avatar
What mild tune/programmer do you guys recommend for my 05 6.0? I currently have exhaust, intake and ficmrepair.com Atlas 40 ficm upgrade (40hp upgrade or 75%, 10hp upgrade, overlap if I add a programmer). My truck has very low miles but no gauges to monitor which is why I am considering a mild programmer/tune upgrade to help improve power and fuel efficiency with my 38" tires
2005 Ford F-250 Black/Brown Lariat 4-door/shortbed
8" Fabtech Lift
20" Rims and 38" Tires
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #2 of 10 Old 02-26-2014, 10:41 AM
duck fan's Avatar
Honestly, spend the money on gauges first. Any tuner is going to make it run hotter as far as EGTs go.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 10 Old 02-26-2014, 11:13 AM
msmith's Avatar
Quoted: 7 Post(s)
^^^^ This!
Mike aka Lineman
AUT VINCERI AUT MORI
as for me and my house, we will serve the LORD. Joshua 24:15 KJV
2015 F350 CCSB FX4
2007 Dark Stone F-250 CCSB Lariat 4x4, SOLD
20" Mastercraft Courser AXTs
CCV reroute
Edge CTS
PMM coolant filter
Diamond Eye 4" turbo back
SCT X3 w/Looney tune
Vision Diesel Stage 1 turbo
msmith is offline
post #4 of 10 Old 02-26-2014, 11:15 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
1st google
2nd bing
3rd here: Ford Powerstroke Diesel Forum - Search Forums
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #5 of 10 Old 02-26-2014, 02:25 PM
COONASS
WHAT HAPPENED's Avatar
All of the above...
Or check my SIG
2005 CCLB FX4
ARP, EGR Delete, 5 inch TB, SCT Livewire, Sinister Coolant filtration, ECL-1, PHP TUNES
Federal Ownership Respectfully Declined
WHAT HAPPENED is offline
post #6 of 10 Old 02-28-2014, 11:21 AM
Mexfdmnb's Avatar
SCT live wire ts has all guages on it so you don't need to put them on the a piller very easy to tune and set up its very user friendly
[SIGPIC]2005 F-250 CCLB zf6
leveling springs, 4" turbo back 5" tip
oil filter bypass, coolant filter
deleted, studded, sinister fuel filter cap,
SCT X3, S&B CAI, blue spring,
truxedo lowpro qt bed cover,
black diamond hg,
stand pipe, dummy plugs, stc fitting, Airdog 150,
Beans Diesel sump, edge insight cts, eadge eas pyro, turbo feed line,
Turbo drain tube, mishimoto 200* t stat, WW2
CCV MOD, High idle mod, PMF traction bars, 08 diff cover, 20" led light bar
Mexfdmnb is offline
post #7 of 10 Old 02-28-2014, 01:55 PM Thread Starter
mad103's Avatar
Will look into the livewire
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #8 of 10 Old 02-28-2014, 02:49 PM
jetjock15's Avatar
Quoted: 113 Post(s)
I've tried a couple different combos and in the end the SCT with DP tunes were best, and look, you even have customer support on this site which is way cool
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #9 of 10 Old 02-28-2014, 02:56 PM
andyjman's Avatar
Quoted: 2 Post(s)
What mex said :-)
What up mex, how's ur truck comin
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
post #10 of 10 Old 03-03-2014, 04:10 AM
I prefer gages and an X3, but a Live Wire is an option. Just do yourself a favor and make sure you can see what's going on in your engine with some kind of gages/monitor.
WLDHRSE is offline
