6.4 ported intake - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By windrunner408
  • 1 Post By WLDHRSE
post #1 of 7 Old 02-25-2014, 03:31 PM Thread Starter
XL trash...
Merc82's Avatar
Quoted: 291 Post(s)
6.4 ported intake
Any advantages to the 6.4 ported intake over the 6.0? What exactly has to be done to make it work on the 6.0? I see from the pictures of the ones posted that others have put on the 6.0 and you definetly have to fab an alternator bracket. Are the gains worth it though over the 6.0 though, does it flow better. I may be able to pic one up on the cheap.
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #2 of 7 Old 02-25-2014, 04:18 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I have looked at this quite a bit (as I've built a couple 6.4 manifolds to run on 6.0s) and I use to think that a fully ported 6.4 manifold would be a WAY better manifold than a fully ported 6.0 manifold. I thought this because of how the elbow/mouth of the manifold is angled more towards the back of the runners but after doing some more playing around with a 6.0 manifold, I now see VERY LITTLE performance benefits (if any at all) to running a 6.4 manifold over a 6.0 manifold that I port. The ONLY benefit I see (and this is why I'll be running one on my truck) is that the 6.4 manifold is a shorter runner height manifold than the 6.0 and due to the runner shapes, it should open up the valley of the motor more for someone looking to stuff two turbos in the valley of a 6.0.
JUGERNAUT likes this.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 7 Old 02-26-2014, 04:58 AM Thread Starter
XL trash...
Merc82's Avatar
Quoted: 291 Post(s)
Thanks Nate, probably not worth the effort for minimal if no gain then. Not for the setup I plan on running anyways with a "stage 2" ( very broad term) style turbo with a 64.7 compressor. I do think it provides a cleaner look, at least with the ones I have seen of yours (Bryan's).
Merc82 is offline
post #4 of 7 Old 02-28-2014, 12:45 PM
I'm in the process of porting a 6.0 intake now that will go on my truck. Then I'll be porting one to go on Dale's truck so he can compare it to the 6.4 (not ported) intake he's running now. I don't think to many people are porting the 6.4 intakes when they use them because they are said to outflow a ported 6.0 intake in stock form. I don't know about that though.
WLDHRSE is offline
post #5 of 7 Old 03-01-2014, 11:20 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
100% correct Nate and this is the reason I run mine. There is one more reason im running mine is that the 6.4l manifold has less volume and this means faster boost pressures sooner. I will be running this in conjunction with the 6.7l cac and that has less volume so spool time "or should I say fill time" will decrease there and I think boost will build a lot faster. These are experiments so who knows. If you want to check volume fill it with water and poor that out in a bucket do the same with the other manifold I found a ported 6.0l holds much more water like 2 inches worth in a 5 gallon bucket. But like Nate said the 6.4l is smooth flowing with no egr stuff and changing a oil cooler is a breeze with a 6.4l intake. This is why I didn't buy a remote oil cooler.
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #6 of 7 Old 03-01-2014, 01:01 PM Thread Starter
XL trash...
Merc82's Avatar
Quoted: 291 Post(s)
So with less volume and smoother flow, would you compare it to the venturi effect like on a carburetor? Where pushing air at a certain speed through a choke point would accelerate the flow on the other side. If it spools quicker, gives a cleaner look and makes changing oil coolers a breeze I may give this more thought. I don't have big power plans just a clean driving fun DD. Being easier to work on is a plus.
Merc82 is offline
post #7 of 7 Old 03-01-2014, 01:39 PM
Term3's Avatar
All we need now is someone with assume TIG skills to fab up a tubular stainless steel intake manifold all polished up to a mirror finish.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
