6.0 turbo - Ford Powerstroke Diesel Forum
post #1 of 16 Old 02-25-2014, 11:01 AM Thread Starter
6.0 turbo
I have an 05 f250 with the 6.0...Getting head studs redone this spring and also have a bad turbo..im looking to upgrade it also but my question is..do I have to stick with a vgt turbo or can I do a non vgt..looking for better performance. .I do a lot of towing with it too
Malakas is offline
post #2 of 16 Old 02-25-2014, 11:31 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Yes you can run a non-VGT, but it's gonna require SCT custom tuning.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 16 Old 02-25-2014, 11:33 AM
JGman141's Avatar
You can switch to non vgt, but you have to also buy the set up as well. I think a s362 would probably do well with towing and make good power.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #4 of 16 Old 02-25-2014, 12:22 PM Thread Starter
So what will I have to do with the harness that currently plugs into my turbo...and who makes that s362?
Malakas is offline
post #5 of 16 Old 02-25-2014, 12:30 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Whats wrong with your turbo? I had a bad oil ring in mine and tore it down and rebuilt it for $55 with a parts kit from Garrett.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #6 of 16 Old 02-25-2014, 01:08 PM Thread Starter
Vanes sticking..no boost unless I hammer it..loud screaching when idle
Malakas is offline
post #7 of 16 Old 02-25-2014, 01:19 PM
peixinho's Avatar
Quoted: 207 Post(s)
sounds like your turbo is probably done. If is is screaching at idle it could be wheel to compressor cover contact.
Are you doing anything else to the truck. It could be a good time to upgrade to a bigger turbo. Maybe a stage 1 vgt... or I hear cutting edge makes great kits to swap over to non vgt.
Did you say you are redoing your headgaskets again??? whey did they fail???
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #8 of 16 Old 02-25-2014, 01:31 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
my vains were stuck too. cleaned them up good with an angle grinder and a brass wire wheel and applied anti sieze to the unison ring. screetching could be bad bushings which comes in the rebuild kit I mentioned. Its worth a look inside to see if you can rebuild it unless you just want to spend a lot of cash on an upgrade.
post #9 of 16 Old 02-25-2014, 02:27 PM Thread Starter
Havent done head gaskets yet..just saying im getting them redone..truck is stock..just intake..exhaust..and tuner..I want more power without the hassle of a vgt
Malakas is offline
post #10 of 16 Old 02-25-2014, 02:28 PM Thread Starter
I have a blown head gasket on the exhaust side over pressuring the coolant system
Malakas is offline
