Barder stage 1.5 or 2 - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 30 Old 02-24-2014, 10:53 AM Thread Starter
It's time for me to get a new turbo. Is anyone running the barder stage 1.5 because that's what I'd rather get but all I have seen is reviews on the stage 2. Just wondering if anyone has any opinions on the stage 1.5
Black 2004 F250
05-07 front conversion
08+ rear conversion
8 inch lift, 22x14 American Force Blades,
Arp Studs, Egr Delete, Edge insight cts, Sct x3 with tunes from Quicktricks, 4 inch turbo back exhaust, S&B intake, coolant filtration kit
blacksuperduty is offline
post #2 of 30 Old 02-24-2014, 11:42 AM
westcoast6.0's Avatar
I've had my stage 2 for a little over a week. It's kick ***. Customer service was great. Give them a call tell him what you got and what you want to do. He will take care of you.
Erick
2005 White CCSB 4X4
MBRP 4" straight pipe
RiffRaff Boots
Updated metal CAC tube
S&B CAI
Zoodad
ARP Head Studs
BPD EGR Cooler
OEM Oil Cooler
BPD Water Pump
Barder Stage 2 turbo
6.4 Banjo Bolts
Blue Spring
Zerex ELC-1 Coolant
SCT X3
Tunes: SPD, SRL+, XTREME STREET
Rudy's Diesel Up-Pipes
westcoast6.0 is offline
post #3 of 30 Old 02-24-2014, 12:15 PM
borsky4's Avatar
Stock injectors run stage one, 155 or 175 with stock nozzles run a 1.5, 155-175 with 30% over nozzles run stg 2.
Stg 1.5 is basically a billet wheeled pmax. I never liked my pmax much (because of lag and less low end) until I run bigger sticks. But I hear a 1.5 with a ported manifold is a good setup with stock injectors. I plan to run 190 30's with my stg2 but I'll have supporting mods like an IC, ported manifold, and stg #1 cam.
IMO of course. Hope this helps
2006 CC SB, SRW, Barder stg #2, Ported manifold, Warren 190 30's, banks CAC, SCT Tuned by/IDP, IDP ficm tunes, nadp trans, fluidampr, FASS LP, Driven RR, edge insight, HPODS, BD ex manifolds, HD y pipe all ceramic coated & wrapped, UCF O-ringed heads with arp's, Colt stg 1 cam with RCD springs and tubes,
6" lift/trac bars, 37's 4:30 gears, Future mods: non VGT T4 64mm BASB
borsky4 is offline
post #4 of 30 Old 02-24-2014, 12:35 PM Thread Starter
I've read where numerous ppl are running barder stage 2 with stock injectors are loving it but I don't plan on running big enough injectors for the stage 2. Biggest I'll go later down the road is 155/30 or 175 stock nozzles. So I was figuring the stage 1.5 would work well for now. Plus I know a good amount of ppl that like there powermax with stock injectors
Black 2004 F250
08+ rear conversion
post #5 of 30 Old 02-24-2014, 01:03 PM
william_ace's Avatar
Quoted: 2 Post(s)
First off, your truck looks great! In my opinion, I would go with a "stage 2" from Barder or a similar turbo from KC. You say now, that you will never go bigger injectors than XX size, but from experience you will want to. If you get the stage 2, you could run up to a 175/75 or even a 190/xx possibly. It will be cheaper in the end for you. The stage 2, also works well with stock sticks so I do not think you will be dissapointed!
WLDHRSE likes this.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #6 of 30 Old 02-24-2014, 01:42 PM
I'm running stock sticks. Stage 2 and love it. Later I may go with 155's. Just be sure to get tunes to support the turbo.
Erick
2005 White CCSB 4X4
RiffRaff Boots
S&B CAI
Zoodad
ARP Head Studs
BPD EGR Cooler
OEM Oil Cooler
BPD Water Pump
6.4 Banjo Bolts
Blue Spring
Zerex ELC-1 Coolant
SCT X3
post #7 of 30 Old 02-24-2014, 01:54 PM Thread Starter
I was just saying I'm not going to go to big for the fact I use my truck for work towing boats quite often. Not anything to heavy but still am towing stuff here and there.
Black 2004 F250
08+ rear conversion
post #8 of 30 Old 02-24-2014, 01:55 PM Thread Starter
Who's tunes are you running with your stage 2 and you ever tow. Spool pretty good with stock sticks?
Black 2004 F250
08+ rear conversion
post #9 of 30 Old 02-24-2014, 01:55 PM
borsky4's Avatar
Haha, opinions are like a$$holes everyones got one, I shared mine. even if you didn't like it. your welcome.
Heres another one, if your going bigger injectors, don't f#$% around and get a stge 2. If you plan on staying stock injectors your best bet will be a stg 1 because you will lose driveablity, low end and probably mileage with a bigger turbo. Even if you know a guy who liked his stock sticks with a pmax...
If I planned on staying with stock sticks I'd get a ported manifold before a larger turbo, reason being, nice egt drop/more power without driveability lost. And possibly cheaper depending on the route taken.
FWIW,most people wont admit that they did a mod and weren't really happy.
IMO of course
PS. if you want opinions on the stg 1.5 ask if there are any people running a pmax with a billet wheel, you'll have more responses. That's what I was running and didn't like it with stock sticks. Next question to ask yourself is are you ever actually going to get bigger sticks?
ttyl
borsky4 is offline
post #10 of 30 Old 02-24-2014, 01:58 PM
Quoted: 2 Post(s)
You can tow, and tow HEAVY with a stage 2 and 175/xx. There are a few around here who tow full weight with that combo.
4" MBRP Turbo Back
