Zf6 swap? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-23-2014, 08:15 PM Thread Starter
Zf6 swap?
The truck is under the knife now and once back together the transmission will be the weak link. A built trans isn't cheap and I'd rather have a standard. I figure I'd need a zf6, dual disc clutch, pedals and probably some other stuff and what kind of fabricating would I have to do to make it run and look like it came from the factory? Is there any shops out there that could do it? No I don't want to sell my truck and buy a standard cause I know that's gonna come up haha
Thanks, jdiamond
Early 04 CCSB, studded,deleted, 190/75's, powermax, warren comp plus, some other stuff
Jdiamond is offline
post #2 of 2 Old 02-24-2014, 06:10 AM
william_ace's Avatar
Quoted: 2 Post(s)
Coming from someone with a zf6, I would recommend that you save up and get a built automatic. Especially after seeing what all you want done to the truck. You can't do a boosted launch, lose boost between shifts, shifts are hella slow etc.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
