Fuel System Question!!! - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By onebadcoastie
post #1 of 6 Old 02-23-2014, 11:56 AM Thread Starter
Hey guys, I have a couple of quick questions.
My pump is starting to get a little weak (used to run at 61psi and is now idling around 57psi with a substantial drop at WOT). I've pretty much decided that I'm going to upgrade to an AD2 with the XDP or Helman Fuel Sump. I'm pretty clear on the installation of the sump; however, have some questions about AD2. For some reason I can't find a YouTube video of a full 6.0 install.
So... will the AD2 lines included in the kit marry up to the XDP or Helman sump? Also, do I need to change anything with the return or can I just use it as normal with my AD2. I still have stock injectors so I know the RR isn't needed, yet. I just want to make sure I can hook the AD2 right up as usual and roll with the blue spring I previously installed!
Also--what does everyone do with the stock pickup once they install a sump? Are you blocking it off with a rubber grommet or something? I can't find anything on this subject. Last question-- what is the average install time for the AD2 on a 6.0? Thanks in advance, I appreciate all of the insight!
2004 F-250 Powerstroke SCSB
EGR Delete, ARP Studs, OEM Gaskets,
Refurbished Oil Cooler, 4" MBRP Exhaust,
SCT Tuner with Gearhead tunes
Triple Pillar with Autometer Gauges
UMfan11244 is offline
post #2 of 6 Old 02-23-2014, 12:09 PM
UMfan, you should do some searching about the ad2, the consensus around here is they're garbage. Most people agree the stock pump is compatible with injectors up to 190. You can run the air dog 150 as a lift pump feeding a good stocker and have all the fuel and filtration you need, the fass lift pump is good also. The guys at Strictly diesel have a good handle on these fuel systems and are very helpful. I'm going to go the 6.4 lift pump feeding the stock pump with a sump, there's a good write up here on the forum, inexpensive also. I wish I was better with forum technique and could post the links but I'm not that savvy yet, easy to find with a little searching though.
Casey
05' F350 cclb born 12-9-04
4 inch down pipe, 5 inch exhaust no cat
atlas 40 ficm tune, SCT tunes, Dashboss
ARP studs, egr delete ,driven diesel regulated return, WPE up pipes
Warren 175/75? ( wish I knew the nozzle size! )
MTW stage II turbo ( this week )
Six inch lift and 35-12.50-18 AT-II's
slvr bullet is offline
post #3 of 6 Old 02-23-2014, 12:18 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Stay far far away from AD2. Just google "AD2 reviews" or AD 165 reviews"...
JGman141 and Heavy_GD like this.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #4 of 6 Old 02-23-2014, 12:44 PM Thread Starter
Slvrbullet, thanks for the info, I've read that thread actually.
Shack, what would you recommend. I keep hearing that every system has significant downsides. If I stick with stock injectors and the SRL+ tune I'll still need some type of pusher won't I? I also really want to switch to a sump system just to avoid the 1/4 tank or less problem and the crappy stock pickup. Let me know what you think.
Thanks.
post #5 of 6 Old 02-23-2014, 01:00 PM
What I'm planing to do is the Fass sump and draw straw setup, then you get the advantage of a sump without a fuel line hanging below the tank. Use this to feed a 6.4 lift pump, oem quality easy to find. All this feeding a stock fuel pump.
Casey
post #6 of 6 Old 02-23-2014, 01:00 PM
Quoted: 10 Post(s)
Build your own system. Get a fuelab 41401/41402 pump or an Aeromotive 1000. Get your own filters and piece them together with a good regulated return. Or you can get the 6.4 pump and use it as a lift pump to feed the 6.0 pump and be done with it. There are a ton of options. The AD150 is designed as a low pressure lift pump and that would work along with the 6.0 pump but the AD165 is just a poorly designed high pressure pump with a significantly high failure rate and poor customer service.
6.4 pump install write-up!!!
Shack
