HELP! Livewire TS with No Start issue! - Ford Powerstroke Diesel Forum
post #1 of 16 Old 02-23-2014, 06:33 AM Thread Starter
Angry HELP! Livewire TS with No Start issue!
Hey folks, I received my Livewire TS from Innovative on Friday, verified that it has the updated firmware and installed it on the truck. I have ran the canned Street and Performance tunes with no issues at all since I put it in. Jump to Saturday afternoon, I received my 3 free tunes from Eric at Innovative, downloaded everything for my desktop and laptop and hooked it up and added the tunes. Well, when I put it on the truck I loaded up the ID Street tune and attempted to change the "tire rev's" from the stock value to 590 to match my 295/70 18's. Well everything seemed to work out good so I turned the key off as instructed and went to grab a few things before heading into town for the maiden voyage. Getting back in the truck resulted in a no start with my ABS light kicking in on the dash and the little service wrench also. The LWTS won't let me even reach the Tune Selection screen to change the tune or edit it because it gives me a "General error code: 11020 Turn key off!" I also get a code trying to get to gauges or diagnostics. The injectors buzz on, GP's cycle, air separator works as it's needed but no response to start. No click at all, just the lights on the dash flicking on and off as the key passes through the motion from pre-start to start. I emailed SCT Emergency Tech Support, sent them a copy of my stock file as they suggested through their initial response and haven't had a bit of luck since. Thanks, Sean
TwiggyTheDrummer is offline
post #2 of 16 Old 02-23-2014, 06:51 AM
Mexfdmnb's Avatar
Wow sounds like your having a crappy day but I also have a livewire ts I run the street Tue most of the time but I don't change the tire rev or any of that but let us know what fixes it!
[SIGPIC]2005 F-250 CCLB zf6
leveling springs, 4" turbo back 5" tip
oil filter bypass, coolant filter
deleted, studded, sinister fuel filter cap,
SCT X3, S&B CAI, blue spring,
truxedo lowpro qt bed cover,
black diamond hg,
stand pipe, dummy plugs, stc fitting, Airdog 150,
Beans Diesel sump, edge insight cts, eadge eas pyro, turbo feed line,
Turbo drain tube, mishimoto 200* t stat, WW2
CCV MOD, High idle mod, PMF traction bars, 08 diff cover, 20" led light bar
Mexfdmnb is offline
The Following User Says Thank You to Mexfdmnb For This Useful Post:
TwiggyTheDrummer (02-23-2014)
post #3 of 16 Old 02-23-2014, 07:03 AM Thread Starter
Yeah man, between the pouring rain and having a 9,000 pound paperweight parked in the middle of the yard. Hopefully a solution is coming soon, I'll be sure to let y'all know if anything comes of it.
post #4 of 16 Old 02-23-2014, 08:14 AM Thread Starter
Anyone ever had this happen or know of a solution that will get me back up and running?
post #5 of 16 Old 02-23-2014, 09:39 AM Thread Starter
Shot of Dash
http://i36.photobucket.com/albums/e2...223141227a.jpg
post #6 of 16 Old 02-23-2014, 10:27 AM
portcity_gt's Avatar
Quoted: 1462 Post(s)
Did you save a copy of the stock tune on your desktop? You can probably load the stock tune into the ts from there and reflash the truck.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #7 of 16 Old 02-23-2014, 10:32 AM Thread Starter
Hey portcity, I did save a copy of the stock tune on my desktop. My only issue is that it won't even let me access the Tune Selection data on the Livewire. I get the error 11020 while attempting to reach the screen and there is no apparent way to bypass it. Is there a way to pretty much force the stock tune?
I also sent a copy of it to SCT as their after hours tech support requested me to do by email.
post #8 of 16 Old 02-23-2014, 11:39 AM
Heavy_GD's Avatar
Quoted: 1656 Post(s)
Feedback Score: 3 reviews
I've gotten this before, I just unplugged the tuner from the OBD and plugged it back into the computer to double check everything. When I came back out and put the tuner in all worked.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #9 of 16 Old 02-23-2014, 03:59 PM Thread Starter
No Dice
Thanks for the help Heavy_GD, I tried it and it isn't doing anymore than it was. I don't know what is going on with this Godforsaken thing.
post #10 of 16 Old 02-23-2014, 04:03 PM Thread Starter
For some odd reason when I turn the key to the on position it will cycle the GP's and the injectors will buzz, the ABS light will kick on then off and then it will kick back on and it sounds like it actually trips a relay causing the interior lights to kick off. However they flash right back on immediately or as soon as you flip the key to the off position.
