SCT X3 - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Lilpooh
  • 1 Post By Lilpooh
post #1 of 5 Old 02-22-2014, 03:35 PM Thread Starter
SCT X3
I found a SCT X3 locally. The guy said it was on a Mustang before. If I buy it will I have to send it to someone to load diesel tunes on it? Also those tuners aren't vehicle specific are they?
2004 Ford Excursion lifted 4" with 35" Nitto ATs, ARP head studs, XDP egr delete, factory oil cooler upgrade, Volant intake, 4" turbo back exhaust
1988 Ford F-250 7.3 IDI
88 Ford is offline
post #2 of 5 Old 02-22-2014, 06:32 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
What to look for when buying used SCT for 6.0
Be sure it's unlocked/not married and has unlocks left. You get custom tunes in a email from the tune writer, no need to send out the device.
Sent from AutoGuide.com App
JUGERNAUT likes this.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
The Following User Says Thank You to Lilpooh For This Useful Post:
88 Ford (02-22-2014)
post #3 of 5 Old 02-22-2014, 06:57 PM Thread Starter
Thanks for the link. I did know that they were married to whatever they are used on. I just wasn't positive if one used with a Mustang could be used on the 6.0. From what I have seen is that it can be used...
88 Ford is offline
post #4 of 5 Old 02-22-2014, 07:02 PM
Powerstroke Techie
Lilpooh's Avatar
Yep, the X3 #3000 and SF3 #3015 will work on several different Ford make/models.
Lilpooh is offline
post #5 of 5 Old 02-22-2014, 08:59 PM Thread Starter
Awesome. I appreciate the info. I got it for $125 and since it should work I'm glad I pulled the trigger when I did.
88 Ford is offline
