6.0 blues have struck again - Ford Powerstroke Diesel Forum
post #1 of 1 Old 02-20-2014, 06:19 PM Thread Starter
jcpsuperduty's Avatar
Hello all. The past two years my psd has been a money pit and now having to put in my third hpop in. Did all the testing and first ipr numbers were low so I checked the ipr and it was damaged as the plastic filter housing was broken and had to suck it out to retrieve it. Changed it out with oem and that was not the issue. So did the air test and injector #7 o-ring was damaged as well. Put in new injector and still not getting better. So finally figured out its the hpop. Going with adrenaline high output and crossing fingers its the last one I buy. I stumbled upon a bpd remote oil cooler system (looks bada$$) that was given to me for some work I did for my mechanic that handles things I am not able to do. So with all that said I would like to purchase some 205/75 sticks. Will I be able to tow with those injectors? And if anyone has the adrenline high output what are your thoughts on it? Thanks in advance for any info.
2004PSD CC Long Bed 4x4, Usual stuff and some more stuff.
jcpsuperduty is offline
