Hypermax Triple Fire Ring Headgaskets - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 63 Old 02-20-2014, 09:15 AM Thread Starter
peixinho's Avatar
Quoted: 174 Post(s)
I have been having head gasket trouble lately. Seems once you get above 600hp the stock oem just don't last long term. I have been doing a lot of research and have tried a couple of things that did not work. I found out about this hypermax kit recently and I really like the idea of it... but I just cant find much more info or reviews on it. Before I pull the trigger I wanted to make sure to check and see if there has been any negative feedback on this set.
This set is not listed on their website. It is a special 3 fire ring design and costs $1,000. The first ring is slightly smaller and takes the brunt force of the combustion gases. The second ring is slightly larger and does all the sealing. The third ring is kinda lack a last resort or backup ring just in case anything manages to get past the first two rings. Then after all the rings you still have you composite graphite gasket to help and to seal all of the water/oil jackets.
This kit requires machine work to the head and not the block. All three rings sit in the same groove... it is not just your typical groove.
They came out with this design for their race truck that was making 1000+hp and running 120+ psi of boost. It held up fine to 100s of hours of racing without any leaks.
Does anyone know anyone running these gaskets? I am trying to find some real world experience. I know Chris (strokin6L) is running their old design and loves it... but its not exactly the same.
Thanks for the help
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #2 of 63 Old 02-20-2014, 09:30 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I know that a motor build is inevitable for me in my future so these things are DEFINITELY on my list now.
ODAWG714 likes this.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 63 Old 02-20-2014, 09:31 AM
portcity_gt's Avatar
Quoted: 1188 Post(s)
Have you checked with cometic? Theyre a popular choice among high hp race cars.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #4 of 63 Old 02-20-2014, 09:40 AM Thread Starter
peixinho's Avatar
Quoted: 174 Post(s)
cometic??? No I will look into that. I heard about a couple of cummins guys using them. Here are the ones that I have looked into and crossed off my list...
Fire rings that don't require machine work
ARP 625s with OEM
copper gaskets with orings
MLS with Orings
Single fire ring with OEM or Graphite gaskets
KC Turbos
peixinho is offline
post #5 of 63 Old 02-20-2014, 09:41 AM
strokin6L's Avatar
Quoted: 3 Post(s)
I honestly think the hypermax kit is your ticket charlie. I would really love to see a pic of their new ring design to see how it differs from the the rings I have.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #6 of 63 Old 02-20-2014, 09:43 AM Thread Starter
peixinho's Avatar
Quoted: 174 Post(s)
If/when I get them I will take really good pics
strokin6L likes this.
KC Turbos
peixinho is offline
The Following User Says Thank You to peixinho For This Useful Post:
strokin6L (02-20-2014)
post #7 of 63 Old 02-20-2014, 10:11 AM
stonepusher's Avatar
IMO OEM gaskets are fine, mine went after 3 years of straight abuse, nitrous run through a VGT is a lot of back pressure and cylinder pressure im sure, especially when I ran it for 2+ years on a stock charger, it took 2 stages of nitrous on a VGT to pop the head gaskets. If they are done right, you will only have to do it once. When I build my next engine it will have OEM gaskets with ARP 625's. I have seen trucks with 600+hp running OEM gaskets for years without any issues, and with the occasional spray. Just my 2 cents and my experiences with them.
2005 F-250 6.0 BTS 4r100,285/150's, TSD sump, TSD fuel system, TSD tuned, Barder stage 3, and some other goodies.THANKS TO TRUCK SOURCE DIESEL!!
11.72@114 Fuel
11.00@126 One stage of gogo juice
stonepusher is offline
post #8 of 63 Old 02-20-2014, 10:40 AM
Yea it might be a custom made thing from cometic but im sure they could do it.
ive had a set in my turbo mustang for years, ive even reused the same set at least three times never any issues.
a lot of 2000-3000hp cars run them.
post #9 of 63 Old 02-20-2014, 12:47 PM Thread Starter
peixinho's Avatar
Quoted: 174 Post(s)
I understand exactly what you are saying and I hope you are right. I know we have spoken through a couple of pm's and I have talked with Chris a lot on the subject. I know Jesse Warren is also going to try going that route and I hope it works great!
The problem for me is that I don't know any guys that have been pushing 600+ hp that actually use it and had their head gaskets last very long. I only know guys who say they know guys? Or guys who have 600hp trucks that never go over 1/4 throttle (Nate ) A lot of the guys that I know pushing 600+ hp and actually use it are usually tearing down their trucks all the time and replacing the head gaskets anyways while they are in there. Mike I thought yours blew very soon after you put on your stage 3 turbo? Do you know if it was leaking before? In my case my head gaskets were not blown. They were only slightly leaking. You would not have known unless you put a pressure gauge on it. But a slightly leaking head gasket will eventually lead to a blown gasket over time, especially if you add a bigger turbo to it.
Most of the gaskets I have seen blew out around the fire ring sealant area half way between the studs. This is because the heads will flex between the studs (no matter how strong the stud is). That is a huge down fall of the MLS style gasket because when the pressure releases slightly it will start to burn/rub off. That sealant can be great if it leaks slightly then when the pressure lets off it will seal right up again. But it will eventually wear out and then the flood gates will open.
Here is a very good read on why copper head gaskets hold up better in high hp applications
Copper Head Gaskets | AERA Engine Builders Association
Here is a quote from the article that is why i feel our stock oem gaskets fail the way they do...
"To an engine builder, the words “High Performance” pre-suppose high pressure, high pressure requires a more robust combustion seal and the best combustion seal is metal-to-metal. I’ll elaborate; many cylinder head gaskets are coated with sealants designed to eliminate fluid leaks. From experience, readers of this article will be familiar with the various types from slick to sticky and while these work well for fluid sealing they are not able to withstand combustion pressure and heat. No matter how good an elastomeric coating may be for coolant or oil, it will eventually scrub off, burn off, or blow off the fire ring area of the head gasket and in performance engines this can happen in a surprisingly short period of time. Once the sealant is gone from the fire ring combustion seal, it’s a short trip to the nearest coolant passage. Silicone, or other rubber-like sealants or coatings should never be placed on the combustion seal in performance engines."
Here is a picture of my last set of blown gaskets. You can see it failed just like the article states. The sealant just started wearing off. Once the sealant is gone your head will leak.
This is why I have chosen not to go with the arp 625s and OEM gaskets. The extra clamping load will not stop the head from flexing under load. ARP 625s will only help to keep the studs from stretching under load. When the heads flex under load the sealant will start to wear/burn out. Once the sealant wears out your heads start to leak slightly... which will eventually lead to a blown head gasket. This is why IMO many guys push huge power for short periods of time with standard ARPs and OEM gaskets. But I know very very few (actually no one) that pushes high hp on a DD for more that a few years with standard OEM gaskets.
This started me looking into copper gaskets. These are an awesome choice and are used by many of the top drag cars. The biggest drawback of a metal to metal gasket is that it does not seal the water/oil chambers very well. This does not matter to most guys pushing high HP drags because they are always tearing down their motors and only run them for short periods of time. I liked the metal to metal sealing around the combustion area but I dont like the potential problems from leaking water and oil.
This is what led me more to the Fire ring idea. You get the benefits of a metal to metal seal around the combustion area. Then just outside the combustion area you still have a graphite gaskets which have worked great for decades to seal oil/water chambers. It seems like the best of both worlds in theory... but we all know things don't always work good in theory and application
Hope that helps explain what led me to this idea
KC Turbos
peixinho is offline
post #10 of 63 Old 02-20-2014, 03:51 PM
I was going to ask you in your other thread if you ever looked into copper head gaskets. I have never heard them mentioned in a 6.0L application and wondered if there was a reason why....
WLDHRSE is offline
