Which injector? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By peixinho
post #1 of 4 Old 02-17-2014, 12:08 PM Thread Starter
Which injector?
Been doing some looking and finally got my truck studded and got money burning a hole in my pocket. I'm thinking 190-225's. I figure if I go with a 190 I won't have to mess with the hpo system. With 190's I assume I'd be limited to about 600 hp. But with 225's I could possibly reach 700. Also which nozzle should I choose? Not gonna be doing any towing, it's an early 04 ccsb if that makes a difference. Any info is appreciated!
Thanks, jdiamond
Early 04 CCSB, studded,deleted, 190/75's, powermax, warren comp plus, some other stuff
Jdiamond is offline
post #2 of 4 Old 02-17-2014, 02:47 PM
peixinho's Avatar
Quoted: 169 Post(s)
I would ask first what you do mostly with your truck and how you use it first.
Do you ever tow?
How heavy do you tow?
How will you use your power (street, dyno, sled, etc)?
Do you mind a smokey truck?
How soon do you plan on upgrading your tranny?
Do you ever plan on upgrading your HPOP?
190s are usually fine with a stock hpop... like you said 205-215 is at the limit of the stock pump. You could actually experience a power loss if you go to big and lose ICP. Twin pumps could solve that problem but it is an extra added cost.
190s seem to be able to hit 600-650 pretty easily these days with a good running truck and a stage 3 turbo. If your goal is to hit 700hp then you might need to go bigger in size and open up the wallet a little more to some of the other mods. Most guys say that a stage 3 turbo clean up 190s really well.
I would not go too crazy on the nozzle size, but that will also depends on where you buy your injectors. Every nozzle is different. I know I had my 285/75s flow benched at right around 240cc. That means that a 75% nozzle is plenty big to dump anything smaller than 240cc injectors. A 190/30 would be pushing it on the small end. So IMO a 190/50 or 190/75 would be a good combo.
Here are a couple videos of a guy running around 190cc injectors and a stage 3 turbo.
This was not a boosted launch. It was just a street truck taking it easy at the track
Here was the dyno run backing up the track numbers
Hope that helps a little
bondajb likes this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #3 of 4 Old 02-17-2014, 03:27 PM Thread Starter
Never tow and my truck before I ripped it apart was real smokey. Don't really like it but I can live with it. And I'll try to keep the stock trans alive for a little while hopefully. And I haven't really looked into the dual hpop much but ik an upgrade is due around 225. I'd like to be closer to 7. Plan on eventually getting other little stuff once I get it up and running good like water meth, ficm tune, ported intake and maybe aftermarket manifolds
Jdiamond is offline
post #4 of 4 Old 02-17-2014, 08:35 PM
andyjman's Avatar
Quoted: 2 Post(s)
I sent ya a pm
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
