Catylic converter removal? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-17-2014, 10:18 AM Thread Starter
kcchief434's Avatar
I have a banks monster cat back exhaust with the dual angled tips I love the look of it but it is not as loud as I would like so I want to take the cat off and remove the guts my question is though can I just take off the two clampsthat hold it in place and will it slide right out it the pipe it goes into has slits so maybe I can use a screwdriver to pry them up then try to move it any other options besides cutting it? Thanks
2006 ford f-350 crew cab 4x4 6.0 powerstroke
6 inch lift with 2 inch coil spacer
38/15.50r18 dick cepek mud country
kcchief434 is offline
post #2 of 11 Old 02-17-2014, 11:22 AM
HMM
HMM's Avatar
Quoted: 2 Post(s)
I can't remember if I removed the crossmember or not but getting the cat on and off was easy. Just unbolt it and you may have to pry on it to get it to come out but it isn't bad.
Now beating all that honeycomb out wasn't fun. It's a little dusty... Or so I've been told...
2006 Dark Shadow Gray Harley #898
HMM is offline
post #3 of 11 Old 02-17-2014, 11:25 AM
ZMANN's Avatar
Quoted: 1911 Post(s)
i took my 06 out without any issues when i punched it
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #4 of 11 Old 02-17-2014, 01:32 PM Thread Starter
kcchief434's Avatar
Well I took clamps off for the cat of course they broke but the cat doesn't move any tips to break it free from each side of the Exhaust? Should I take a couple hangers off?
post #5 of 11 Old 02-17-2014, 01:34 PM Thread Starter
kcchief434's Avatar
Should I try to pry it out with a screwdriver
post #6 of 11 Old 02-17-2014, 07:50 PM
andyjman's Avatar
Quoted: 2 Post(s)
Get some pb blaster or wd40 and spray all the slits in the pipe by the cat and use a rubber mallett or a hammer with a tennis ball on the end.. anything to prevent metal to metal contact, and tap it in a foreward and the backwards motion, and once it gets loose wiggle it side to side and it should come out. Just soak the crap outta it before u try and remove it. Dropping the crossmember is super easy and gives u more room to work.
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
post #7 of 11 Old 02-18-2014, 08:37 AM Thread Starter
kcchief434's Avatar
Well I just finished gutting my cat it didn't really make a difference just gave it a little more whistle but thought it would do a tad more oh well one more question it has a small pin leak where I did it will this be ok? Will I gain any performance or mileage
post #8 of 11 Old 02-21-2014, 03:43 AM
You should have just went with an MBRP FAL414 dummy pipe and kept your cat intact for emissions and only install it for smog.
Bodywerks0660 is offline
post #9 of 11 Old 02-21-2014, 06:46 AM
Dub976's Avatar
Is there enough room to fit a 3.5"-4" increaser with this test pipe? I have a magnaflo cat back and would like a little more tone out of it.
2007 harley f250 6.0l almost stock except for a looney tune, coolant filter, cai, cat back/cat delete, ported intake manifold, studded with a new oil cooler and egr delete. with a edge cts to keep an eye on things.
Dub976 is offline
post #10 of 11 Old 02-21-2014, 06:52 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
If you want the whistle, pull the muffler off too.
You should be ok with the pinhole, you may smell exhaust in the cab though...
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
