Straight pipe whine - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 74 Old 02-16-2014, 09:44 AM Thread Starter
Brent Beeler's Avatar
Straight pipe whine
So I have an 07 6.0 with SCT IDP tune that I've just straight piped and I've noticed a bit of a whine at certain loads/RPM's (not talking about the whistle) is this common and to be expected? Anyone else experiencing this whine?
Thanks in advance!
Sent from AutoGuide.com App
Brent Beeler is offline
post #2 of 74 Old 02-16-2014, 10:21 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1785 Post(s)
Feedback Score: 4 reviews
If you did a full turbo-back, check for any leaks that may have happened while installing the kit. Downpipe and bellows (I know you probably didn't touch them but moving stuff around sometimes will cause a crack) or any other exhaust joints
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #3 of 74 Old 02-16-2014, 08:23 PM Thread Starter
I Put a gutted cat on this thing a year ago and it had a whine so I put the good cat back on and the whine Went away now I have put another gutted cat with a pipe through the center and I've got the wine back but it's not as dramatic, But still a little on the annoying side. Does everyone that is straight piped have this whine or is it just me? The whine is heard usually at gradual acceleration
post #4 of 74 Old 02-16-2014, 09:12 PM
I've got a humm/rumble like a freight train passing by from a distance under normal cruising speed load, around 2k rpm. But no whine. Yours sounds like an air leak or a turbo issue. Straight pipes take away the 'quiet' from the turbo so you can tend to hear everything going on with it. a nicked turbo blade or sticking guide vanes might cause a whine.
Bodywerks0660 is offline
post #5 of 74 Old 02-16-2014, 09:17 PM Thread Starter
Straight pipe whine
Yeah, it's not a very high-pitched whine and all more like A high-pitched hum almost sounds like a whining rear end. So maybe the cat drowns that sound out and that's why I'm not hearing it so much with a good cat on there? Really want to keep it straight piped because I love the sound but that hum I know it's not sticky veins in the turbo i've experienced that before
post #6 of 74 Old 02-16-2014, 10:10 PM
yeah, if the whine you speak of seems to match the 'pitch' of the motor rpms vs the pitch of a turbo spinning at 30k rpm then I'd say the turbo is fine, and it's either the same noise I have that you have to just deal with(or put some sound-deadening material over the cat-delete pipe?), or maybe there's a part of the exhaust touching the chassis somewhere or putting an excessive tortional load on the isolation mounts to where they are transmitting vibrations to the chassis more.
post #7 of 74 Old 02-16-2014, 10:16 PM Thread Starter
I'm going to try to make a video and post a link to it here in the next day or two so you all can hear it and tell me your opinions. Starting to think it's just the nature of the beast being straight piped in all
post #8 of 74 Old 02-16-2014, 10:51 PM
Probably so. Pulsating diesel cumbustion gasses flowing down a pipe with nothing to stop them will probable tend to resonate wit a good bit of authority.
post #9 of 74 Old 02-17-2014, 02:32 PM Thread Starter
Straight pipe whine
Here you go tell me what you think
Hopefully you can hear it
http://youtu.be/WXclObyaXU4
post #10 of 74 Old 02-17-2014, 02:38 PM
Straight piped here, guess Ive never heard that noise. The pitch does sound rpm based. You sure your exhaust clamp on your turbo is secure? When I did mine I thought the clamp was back on correctly,after double checking it was a little ****ed.
2006 F250 Lariat Bulletproofed
2006 F350 XLT bulletproofed SOLD
1983 Mustang GT 410/C4 SOLD
MustangSmitty is offline
