sct tuner - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-29-2008, 09:55 PM Thread Starter
sct tuner
Hello guys and gals haveing some trouble's with my new sct flash,i just recieved from innovative,should i be able to just plug in and down load the custom tune into my truck ecu?or do i need to register it 1st,i got the strategy # wrote those down what do i do want to burn those hides.
coal burner is offline
post #2 of 4 Old 10-29-2008, 10:08 PM
back in the saddle
shu873's Avatar
First off, welcome to the .org!
As for your questions. I'm not sure where you're at with everything. You ordered and received an Xcal3 from innovative correct? Generally you will receive the unit, plug it in to your OBDII port and get your strategy. Next you will email the strategy to Eric, the owner of Innovative, and he will email you your custom tunes for your specific truck and strategy to you attached as ".ll3" files. You will need to go to SCTflash.com and download a program called "liveload" and various drivers, or if you got a CD with your Xcal that should work too. You use liveload to load your files/tunes to the Xcal unit via a USB cable connecting your PC to the flash tuner. Once you've loaded the files on the Xcal you simply plug the Xcal in to the OBDII port and follow the on-screen instructions. Sorry if I'm telling you a bunch of stuff you already know, I just didn't understand exactly what you were asking in your post. Hope this helps, and if you have anymore questions, ask away
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #3 of 4 Old 10-29-2008, 10:20 PM Thread Starter
Kurt thank you,this is my 1st time with a flash unit of any kind i did not no i had to email strategys,will email Eric, hopefully i can burn those hides tomorrow
post #4 of 4 Old 10-29-2008, 10:20 PM
back in the saddle
shu873's Avatar
No problem. Let me know how it works out.
Also if you do have an Xcal3, they come with 3 "canned" tunes already loaded. You can try these out while you wait for your customs.
Kurt
ARP's, EGR blocked
Banks technicooler
shu873 is offline
