Towing and exhaust - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-16-2014, 03:06 AM Thread Starter
sixltr's Avatar
Towing and exhaust
I have a 2006 f350 dually, I use it to tow a fifth wheel toy hauler. The trailer weighs in around 14000 lbs, I am interested in replacing turbo back exhaust. I want to know if anyone is using a 5" system with a fifth wheel? Or exhaust recommendations by users that tow heavy trailers.
2006 EC Dually 4x4 4.10 Auto
Batmowheel
Sct livewire ts
4" Flo pro exhaust
Cat elc
Bd boot kit
Rancho 7000 shocks
Firestone air bags
Rotella T6, Archoil 9100
PHP Ficm tuner
Studs with OEM gaskets
S&B cold air intake
Sinister coolant filter
Spearco Intercooler
sixltr is offline
post #2 of 11 Old 02-16-2014, 07:42 AM
05f250inmn's Avatar
Quoted: 3 Post(s)
I have a diamond eye 5" turbo back straight pipe. I tow a 32' 5er and it is loud while accelerating but once up to speed it is fine.
05f250inmn is offline
The Following User Says Thank You to 05f250inmn For This Useful Post:
sixltr (02-16-2014)
post #3 of 11 Old 02-16-2014, 07:47 AM Thread Starter
sixltr's Avatar
Are there any clearance issues with a 5" system and a fifth wheel trailer?
sixltr is offline
post #4 of 11 Old 02-16-2014, 08:07 AM
05f250inmn's Avatar
Quoted: 3 Post(s)
Not understanding what you mean? Are you talking about stacks? My exhaust is in the factory location.
post #5 of 11 Old 02-16-2014, 08:31 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
If your referring to bed sagging from the weight, you won't get a good answer. Different 5th wheels have different king pin weight.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 11 Old 02-16-2014, 10:39 AM Thread Starter
sixltr's Avatar
I just want to make sure it will clear, my trailer has just over 3000lbs pin weight.
Batmowheel
Sct livewire ts
4" Flo pro exhaust
Cat elc
Bd boot kit
Rancho 7000 shocks
Firestone air bags
PHP Ficm tuner
S&B cold air intake
Spearco Intercooler
sixltr is offline
post #7 of 11 Old 02-16-2014, 10:46 AM
jetjock15's Avatar
Quoted: 113 Post(s)
I tow with a DE setup and it works great I run the DE muffler though never tried straight pipe
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #8 of 11 Old 02-16-2014, 10:52 AM Thread Starter
sixltr's Avatar
Are you running de 5" with a fifth wheel
Batmowheel
Sct livewire ts
4" Flo pro exhaust
Cat elc
Bd boot kit
Rancho 7000 shocks
Firestone air bags
PHP Ficm tuner
S&B cold air intake
Spearco Intercooler
sixltr is offline
post #9 of 11 Old 02-16-2014, 02:19 PM
jetjock15's Avatar
Quoted: 113 Post(s)
I'm pretty sure I could go measure, I pull a 42' toyhauler.
The Following User Says Thank You to jetjock15 For This Useful Post:
sixltr (02-16-2014)
post #10 of 11 Old 02-18-2014, 12:22 PM
My truck is still stock and I am starting to consider things to do and one of them is the turbo back exhaust. I also tow a 42 foot Toy Hauler and the Pin Weight is around 3000 pounds. I have air bags in the back, I got them installed when the truck was new since the purpose of the truck was to tow a heavy fifth wheel. The air bags keep the rear nice and level regardless of load so you could just add those to your truck along with the larger exhaust. Let us know what you end up with.
Carm
2015 F-250 4x4 Platinum Gas
Gone and missed:
2007 F-350 4x4 Lariat Tow Boss DRW Diesel
(Purchased March 2007)
cavlino is offline
